SD-512 intermittently misfolding
  • Aquatic
    • Sep 2015
    • 3
    I have a C754e with a FS-535 finisher and a SD-512. It seems to fold some half fold booklets either skewed or in the wrong place. Sometimes it will fold an inch from the lead edge or it would do a skewed fold close to midway down the page. It also seems to only begin to do this after about 100ish booklets. It did it after a 100, then 50 then every other one intermittently. paper path was clear, cleaned the plates, cleaned the rollers, updated firmware. Unfortunately the manual doesn't list much but the adjustments. The machine has a little over 1mil copies, and the paper is run from tray 1. Anyone run into this or have any ideas?
    • 23010
    Re: SD-512 intermittently misfolding
    Not just this saddle stitcher, but on others, the most important thing seems to be getting the paper tray guides snugly on the paper, and displaying the correct paper size. If the guides are loose by 3mm it will skew and jam constantly. If it's displaying paper size CUSTOM or any other paper size it will jam in the saddle stitcher. What media type, gloss? =^..^=
    • Aquatic
      • Sep 2015
      • 3
      I checked the tray and loaded a fresh ream of paper myself. The guides were snug. The paper was Boise X-9 plain copy paper.
      • tech51
        • 846
        Check the two mylars that guide the paper down into the stacker. They are the ones that sit just above the paddles that pull the paper down.
        I had one with a split in it that caused all of your symptoms plus jamming in my case.
        The split was very difficult to see, but once repaired the unit ran flawlessly.
        There is also a mod for the paper gripper that the paper drives into.
        • Gaffers01
          • May 2011
          • 335
          Yep I second the Mylars, when I get this problem I always replace these mylars.
          They often look fine when inside the machine.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            do you have info on this gripper mod ?
            I've had some techs rebuild that gripper section which has fixed some issues in the past.
            • nullskull
              Learning
              • Aug 2023
              • 450
              Hello i know this is an old thread but would you happen to have a picture of where these mylars are located?
