Bizhub 454e fax problem
  • KM7155
    • Aug 2008
    • 146
    [Misc] Bizhub 454e fax problem
    Hi Guys,
    any advise for below issue?
    this machine sending fax with no issue, just that it cannot receive any incoming fax.
    confirm the fax line is ok, seems the machine not wake up to the incoming fax.
    any help will be much appreciated.
    • 23009
    Re: Bizhub 454e fax problem
    When you say the fax line is fine, do you mean that you connected an analog telephone to the customers phone line and dialed the fax number from your cell. Then the telephone rang (preferably peaking around 110vac). Then when you answered you could hear the sender? That's what I mean when I say the line is fine.
    Is the MFP set to Auto Rx? Is it set to Normal ring? Is the phone cord connected to the LINE connection, not the handset connection? =^..^=
    • KM7155
      • Aug 2008
      • 146
      Hi, yes, i connect the fax line to an analog machine, when i dial the number from my mobilephone,
      it rang from the analog phone, so i assume the line is working fine.
      this is a newly setup machine, the weird thing is it can send out faxes.
      yes, the fax is set to auto Rx, yes, its in normal ring and in Line port.
      confirm with another FK-511, same issue.
      • darry1322
        • Oct 2010
        • 817
        Originally posted by KM7155
        Hi Guys,
        Will it receive a fax while it is currently awake and active?
        In other words, is it a fax issue or a sleep mode issue?
        • kingarthur
          • 1369
          is this replacing a fax that was already it situ, have you fitted the fax cable that came with the fax kit, or have you used a fax cable that was on the customers premises, when you phone the fax from your mobile...what happens
          • KM7155
            • Aug 2008
            • 146
            Hi, the fax is not working either in active mode or sleep mode.
            • KM7155
              • Aug 2008
              • 146
              Hi, i have try to change the fax cable, problem still there.
              This new machine replace the old KM421 machine.
              When i call from my phone, it just ring, cannot go into
              Data mode.
              • darry1322
                • Oct 2010
                • 817
                Is the Marketing Area set correctly for the fax unit?
                • KM7155
                  • Aug 2008
                  • 146
                  YES, marketing area is set to correct country.
                  • allan
                    RTFM!!
                    • 5462
                    Is it set to line1 or line2?
                    Had a couple of bad new FK-511's at a time doing the same thing. Check the error log for any codes.
                    Whatever
                    • wseyller
                      • Sep 2012
                      • 1129
                      I was told by Konica Minolta support today that there is a special firmware coming out very soon that addresses issue with many models that have problem with fax when copier is in sleep mode.
                      Sent from my XT1254 using Tapatalk
                        • 23009
                        • KM7155
                          • Aug 2008
                          • 146
                          my problem is the fax is not working even not in sleep mode.
                          • KM7155
                            • Aug 2008
                            • 146
                            if the fax is set the line 2, will it be able to fax out? i confirm the fax is set the line1 in the service mode.
                            • emujo
                              • Jun 2009
                              • 3009
                              Most of our fax issues are caused by a non analog line...Just because you see a fax cable coming out of the MFP and disappearing into the wall does not mean it's a analog fax line...Some of the other issues are already mentioned...country code is another culprit. We also turn OFF ECM, and JPEG sending. There is a 2 wire fax line that helps eliminate cross talk. Putting the MFP in OFF-HOOK and manually faxing can help diagnose problems, also dial the MFP from your phone and see what kind of answer you get. Be sure the fax is wired to the correct slot (both the pinned and USB cable, they are labeled FAX1). Fax should be initialized at setup and you want to do all your changes after the initialization. Ask the customer to show you the phone bill with the line charge on it...I have seen many converters work, but again, when they fail (protocol error, missing images, 1/2 sheets ect) almost all the time it's due to a digital line...The weird thing is I've seen a bizhub 350 work flawlessly for 4 years on a digital line, but the replacement MFP (C360/C224e etc) was buggy from the get go. You have to assume that this is due to the low fault tolerances of a microprocessor controlled fax board. The service handbook lists the values for send/receive, might be a good idea to get a line tester to check these values. Emujo
