c364e : problem with ADF
  • dc-master
    • Jul 2015
    • 39
    Hi,
    We recently bought a c364e with a ADF DF-624 and the problem is that the ADF shows no response. we even checked the cable connecting the ADF to the main machine and it showed 24v signal inside the cable.
    Also there is no ADF menu in service mode.
    do any of you guys have any suggestions?
    thanks so much in advance.
  • habik
    • 2013
    Re: c364e : problem with ADF
    Originally posted by dc-master
    Hi,
    Page TWO > there is ADF.
    Firmwares HERE
    • allan
      RTFM!!
      • 5462
      Did that machine come with setup instructions?
      The main body can take a DF-624 of a DF-701(dual scan)
      Go to service mode and look for the ADF setting under system.
      Select DF-624 and cycle the power.
      Or do you get the message on the copy screen that something can not be used?
      Whatever
        • 23010
        I think I would start by looking at System2 > Options > and see if the DF is SET. If yes, the ADF menu will appear in the service menu. That does appear in the setup instructions.
        • dc-master
          • Jul 2015
          • 39
          Thank you all
          If your mean is page 2 of the main menu in the service mode, I don't have any.
          in service mode, only I have 1 page on main menu.
          Service mode --> system 2 --page 2--> ADF settings --> DF-624 (it is highlighted and selected)
          but I don't have any specific menu in service mode for ADF and also when I'm putting paper(s) to ADF, as I know the light should be on. but I can't see any action.
          I tried Service mode --> system 1 --> problem unit isolation set
          and set and unset the ADF. but again no result.
          Do you have any other idea?
          or how I can be sure that the ADF hardware is okay?
          • habik
            • 2013
            Thank you all
            Service mode --> system 2 --page 2--> ADF settings --> DF-624 (it is highlighted and selected) > END > EXIT
            Switch machine off with main power switch and wait at east 10 seconds.
            Power up
            Firmwares HERE
            • dc-master
              • Jul 2015
              • 39
              Power up
              I did it several times
              no result!!
              • allan
                RTFM!!
                • 5462
                Is the pick up roller lifting up on start-up?
                If its a new machine get KM involved.
                Whatever
                • dc-master
                  • Jul 2015
                  • 39
                  I can't see/feel any pick-up roller movement.
                  Actually, we don't have Konica agent in my country and I bought this from outside and import it.
                  I can return it to the seller but it will cost me a lot and I'm trying to be sure that ADF have some hardware/technical problem and then return it.
                  • habik
                    • 2013
                    What firmware is it on at the moment?
                    Sent from my iDon't believe in marketing device using Tapatalk
                    Firmwares HERE
                    • mo0651
                      • 1054
                      We had to replace the ADF cable that looks like a USB cable. Black in color. We had a machine throwing the error code for ADF. You have not other codes?
                      • emujo
                        • Jun 2009
                        • 3009
                        You should be getting some kind of error code if the ADF is electronically installed but has a problem..
                        1. How many cables are running from the back of the ADF? 1=DF-624, 2=DF70X.
                        2. Remove back of MFP and double check cables are actually plugged into a small 4x4 board. If so remove and reset board and ribbon cable.
                        3. Check service mode for ADF firmware version. If none listed then you probably have a ADF board issue, or a power problem. Emujo
                        • dc-master
                          • Jul 2015
                          • 39
                          Please check these pictures (I don't know which one I should tell you)
                          • dc-master
                            • Jul 2015
                            • 39
                            I don't receive any error code.
                            also I checked the ADF cable socket (on the main machine) and we had 24v voltage on that but I didn't check the other side of the cable that connected to ADF
                            1- one cable
                            2- please check the below pictures
                            3- I uploaded firmware pictures in my last post
                              • 23010
                              There have been a few upgrades since K2. Firmware is currently at G00-K6. I don't expect that it will resolve your problem, but it's a preliminary step you need to take. =^..^=
