bizhub 222 artefacts
  • adrianG
    • Feb 2015
    • 15
    Hallo,
    I have a problem with bizhub 222 machine,a bunch of strange artefacts appearing on paper on printing and copying also.
    this will ocur on every pages
    Thank you!!!
  • Copier Dork
    • Sep 2015
    • 5
    Re: bizhub 222 artefacts
    I have seen this several times before, and I believe that your charge corona is arcing to the drum surface.
    This could be caused by several things:
    -broken CC assy (grid is loose)
    -worn drum shaft (s)
    -bad DS rollers in the DV unit. <-Most likely
    There is a mod available for the DV kit which replaces the all plastic DS rollers with a bearing roller.
    Part #A1UDR90100
    The kit includes 2 new DS Rollers as well as some new style spacers and end bushing for the mag roller
    Hope this helps
    Trevor
    • copyrooks
      • Oct 2013
      • 206
      My guess is replace the developing unit, along with the developer.
        • 22911
        Drum arcing to: a) grid, or b) developing roller. =^..^=
        • adrianG
          • Feb 2015
          • 15
          thank you all,i will try those when i get to my client office.
          • Don N.
            • Nov 2011
            • 409
            Is the drum scored in the right side where the white trans roller finger contacts it? Are there upgraded dv collars on mag roller? Is the mylar torn at end of mag roller? How old is trans roller? You can take some, not all shims out of trans roller to prevent scoring, especially on rear side. New dv unit is about $100 + dv. Drum r/b kit & new t. roller & done for under $200.
            Sent from my Nexus 5 using Tapatalk
