Re: FS-534 alignment plate wearing.
I have a little more information on this topic. The metal plates are holding up fine at 500K, no paper cuts of any sort. I did see the machine recently for something similar though. The pages were skewing and piling up in the stapling tray because one of the eject belts had jumped several teeth. The first set usually ejects, but the second skews, and the third piles up upon the second set. I wish there was a simple way to re-align the eject belts, but ultimately the center eject belt assembly must be out of the finisher to get it re-aligned.
The paper jam code is primarily J7218, but also J7217, J7221, and J7219. The adjoining machine got the mylar modification is a partial success, but not good enough for me. The regulating plates survive OK, but the mylar still gets cut up at 300K, and requires just as much work to change the mylar. The eject belts were also out of time. This is something I'm going to have to keep a closer eye on. I don't know which causes which, or perhaps they are totally unrelated, just close proximity.
