bizhub 211
  • Orion2010
    • Jun 2015
    • 176
    bizhub 211
    hello to all,
    i have bizhub 211 i change drum, blade, developer , i copy 50 page and displayed this problem IMG_1201.jpg, when i spin with hand it clean, but when put in machine does clean. any idea ?
    thanks
    • 14812
    Re: bizhub 211
    It looks like it is pulling dev. Check drum ground and grid.
    • Hansoon
      • Sep 2007
      • 3389
      Re: bizhub 211
      Looks like the toner recycling isn't functioning. Have a look at the little gears which drive the recycling screw and see also if there is compacted toner in the pipe. Likely there will be noise too from popping gears.
      Hans
      • Orion2010
        • Jun 2015
        • 176
        Re: bizhub 211
        Hans
        you say to change toner?
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          Re: bizhub 211
          Did you run F8 after installing drum & developer?
          • Orion2010
            • Jun 2015
            • 176
            Re: bizhub 211
            no i dont know how?
