when printing i have to choose the tray manualy ! ineo + 454 e
  • jakani
    • Dec 2014
    • 147
    when i print a document i have to choose the tray1 manually even if both of theme (tray 1 a 2) full of paper , every time i print a job the machine says : ''there is no matching paper size. place paper in bypass tray''
    any body have any idea about this or how to solve it so the machine print directly ,
    thanks in advance for any help or any suggestions
  • Elmo
    • Feb 2010
    • 541
    Re: when printing i have to choose the tray manualy ! ineo + 454 e
    Check what size paper is selected on you print driver
    if it is not the same as the paper in your trays the machine will ask you to place the correct size on the bypass tray
    your print driver on your pc may be default to a different size
    I Used To Live To Fix Things Now i Fix Things To Live
    • jakani
      • Dec 2014
      • 147
      thank you sir for your suggestion
      i checked that it it is selected to A4 and i print A4 and in the trays there is A4 paper still i have to select manually !
      • Elmo
        • Feb 2010
        • 541
        so your driver has A4 selected,plain paper type and auto paper tray selected
        and the machine trays are set to A4 and plain paper type
        is this a new install or has the machine been working ok and this error just started
        did you try uninstall and re install the driver
        • jakani
          • Dec 2014
          • 147
          no it's not a new install it's was working just fine ,
          i didn't try to reinstall the driver because it's on printing server and there is a lot of user already installed it on their PCs i think i have to change the name and reinstall it again !
          thanks for your quick reply and your suggestion
          • Elmo
            • Feb 2010
            • 541
            there may have been an update to the server or pc that has affected the driver
            does the same problem happen on other pc's
            • jakani
              • Dec 2014
              • 147
              yes the same problem on all pc's ! i will check out the driver like you said ,
              so there is no parameter on machine that could have been changed by someone and the machine started acting like that ?
              thank you sir
              • Elmo
                • Feb 2010
                • 541
                the message tells you that the machine does not have the correct paper size
                but you know it has and it shows in the machine display
                so the only conclusion can be the information sent from the pc's is incorrect
                it is prossible the server has had an update that is causing the problem
                if you can connect your laptop to the machine and print this will help prove it
                • jakani
                  • Dec 2014
                  • 147
                  oh yes i will try that , thank you very much sir
                    • 14653
                    What size and type of paper is the machine asking for. When there is a message like that it usually says something like "place A4 thick 2 paper in bypass".
                    What is the exact message?
                    • jakani
                      • Dec 2014
                      • 147
                      it asks for A4 i think , but i don't have the exact message right now i will see about that and reply soon
                      thank you
                        • 23006
                        The last time I saw this exact issue there was a school administrator that created her own PDF documents with paper size: Custom 11 x 8 1/2.
                        Not Letter! Custom 11 x 8 1/2 original size will not auto select the Letter paper, but it can be manually selected as a print driver selection. =^..^=
                        • jakani
                          • Dec 2014
                          • 147
                          thank you blackcat4866 for sharing ) and thank you elmo for following this with me
                          i found that the problem is in tray configuration they switched it to use recycled paper and they print A4 plain paper , and i chaged it in copy window > tray settings
                          thank you very much
