BizHub 283. First time for everything
  • copyman
    Owner / Technician
    • Sep 2005
    • 4639
    I have worked on many Bizhub's and have never seen this before. I bought this 283 off lease and when you turn machine on, after the hourglass is on for a few seconds a company's ad comes on for a few more seconds, then the basic screen with ready to copy. Looks like the ad is for the company that must have sold & serviced the machine before being sent back to leasing co.
    Anyone know how to get rid of this. Even though it is only for a few seconds hate to sell a machine and the customer sees a different company name on the display. I tried formatting the HDD but that didn't work.
    Any help appreciated getting rid of this.
    Thanks in advance
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: BizHub 283. First time for everything
    you are talking about the custom boot screen, its there for dealers to customise the machine.
    You can remove it, I'll see if i can find the instructions.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4639
      Hey EarthKM Tech,
      Yep that sounds like it is the dealer boot screen. Really appreciate if you can help me remove it.
      • splblazer91
        • Jul 2014
        • 204
        in service mode there should be a button that says "Boot Up Screen". go there and see if it gives you the option to delete the file. Ive never had to delete one so im just guessing here.
        • copier tech
          • 8131
          Turn on the machine while holding down utility/counter button, wait till you see a black dot in the corner of the screen & release.
          You then get the option to delete the boot up screen.
          It's a nice option to add, looks quite professional, I add my company logo to all out Bizhubs.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4639
            Copier tech, thanks for the info. I also found tab in tech rep mode under sys 2 and deleted it there. How hard is it to add company logo to boot screen? Is it done with a flash drive or connected to PC?
            Thanks again
            • copier tech
              • 8131
              Yes easy to do, you just need the imaging toolkit program, this software coverts your chosen picture to the correct name & file type, you then simply put this on a usb pen drive, plug it into the usb port near the control panel then install the picture in service model, level 2 boot up screen.
              • shadow038
                • Jun 2015
                • 9
                Service Mode
                System 2...the second page
                Bootup Screen
                select delete
                Should remove the image
