Bizhub 423 series fusing rollers
  • SmellsHot
    Head Tech
    • 512
    Anyone find a source for a UFR on this series? They wear so damn quickly.....and there killing my maintenance rev
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
  • Hansoon
    • Sep 2007
    • 3385
    Re: Bizhub 423 series fusing rollers
    Call Hans: touchpanel[at]rex-technika.com How many pcs would you need?
    We produce these:
      • 23008
      Correct me if I'm wrong Hans, but I seem to recall that the bizhub 350 hot roller fits. So do the HR claws from the bizhub 500 or 501. =^..^=
      • Hansoon
        • Sep 2007
        • 3385
        Yes Cat, its the same as is also with the UFR from the old Di3510. All are the same. We developed a roller which has a much better Teflon surface. The claws I don't know cause we never have to change them strange enough.
        Hans
        • SmellsHot
          Head Tech
          • 512
          We produce these:
          What yields are you getting out of your modified rollers?
          I'd take a dozen if the price is right
          • Hansoon
            • Sep 2007
            • 3385
            We ourselves are having machines with up to 130K without showing substantial wear until now. I expect them to reach easily 200K or more.
            Drop me a mail than I prepare you an offer for 12 pcs.
            Hans
              • 14737
              Once we switched back to OEM toner we doubled the life of the UFR on these machines. I think it has something to do with the fusing temperature of the toner, so it sticks to the paper rather than sticking to the roller and then being picked up by the thermistors and sep claws and scoring the roller. We also don't get the wear ring on the drum as early as when we were using crappy aftermarket toner, and we tried quite a few suppliers, none of them were any good.
              • ni311
                • May 2008
                • 658
                Too bad KM don't offer these rollers as parts, you have to change the whole unit... from what I know, the Katun rollers are no good...
                Konica Minolta Error Codes - Explanations and Solutions
                • CraigW
                  • Dec 2010
                  • 417
                  The 200-350s would go 400-500k without problems.
                  223-423s are lucky to make it to 1st PM without streaks appearing.
                  • CompyTech
                    Super Tech
                    • Feb 2011
                    • 706
                    Agreed.. Though I've been fortunate enough to warranty a few fusers through KMBS via the Y&PPP.
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      We use rollers from Image Supply, I think. Part # PP2227U or close to that- just going off memory. Getting 200+K out them which has been better than OEM KM.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • srvctec
                        • Oct 2009
                        • 827
                        Actually might be Precision Roller and the number on the box is 06601.
