KM Bizhub C554 LK-101 V3 Installed Bizhub Marketplace
  • Timoteo82
    • 39
  • allan
    RTFM!!
    • 5459
    Re: KM Bizhub C554 LK-101 V3 Installed Bizhub Marketplace
    I wonder if there is different installer guides for the "e" series and the older machines?
    Whatever
    • Timoteo82
      • 39
      I checked it all goes back to the same install guide and lists both models.
      • allan
        RTFM!!
        • 5459
        It does not seem to be supported on the non "e" series machines.
        But this suggests a possible fix. You need IWS 2.0.
        Whatever
        • Timoteo82
          • 39
          Originally posted by allan
          https://www.bizhubmarketplace.eu/en/support.html
          That is the euro site (dont have access)... I am in the US. What does not seem to be supported on the "non e" series machines. How to get IWS 2.0? I don't see this anywhere. I attached the guide I am working off of. It shows the C554 second down on the list. Then the e-series below that.
          • emujo
            • Jun 2009
            • 3009
            The guide list the firmware level as XXX-70, not 72. Also, there is a step addressing IWS settings for the C754 and later. I know that on the e series you don't have to change this soft switch (150) but if I remember (and we do have market place installed on both e and non e) you had to make this change to get it to work. I have the corporate announcement app installed on a fleet of non e MFPs. Not exactly the same as the market place app, but pretty close as to MFP settings. Also, the installer version was updated a few months ago. Have you updated your version? Emujo
            • Timoteo82
              • 39
              Yes the guide lists that firmware the previous version. The machine had already been updated to 72. (is there a way to go backwards). I see the step about enabling the IWS but the installer does that for you as well. The software switch (150) needs to be changed which I believe we have done because it states " (required to enable the Web browser in the MFP)" which the unit is able to web browse. Will the web browser still work if this has not been switched (150)? Ya the installer forced the update to v. 1.7 (Something) when it gets downloaded. I am just so stumped.
              • allan
                RTFM!!
                • 5459
                Get XXX-70 firmware. I suppose you load it as normal.
                Whatever
                • Timoteo82
                  • 39
                  I have it the machine wont accept it just keeps saying n.g.
                  • allan
                    RTFM!!
                    • 5459
                    Installing a ROM? like Pluging in a PIC?
                    ROM and firmware is not the same thing.
                    Or its like konica iROM
                    Or ROM is the reference to the LK itself.
                    Whatever
                    • Timoteo82
                      • 39
                      Can you give me more insight on this. Maybe im not understanding this correctly. I don't know where I would get the correct ROM.
                      • Timoteo82
                        • 39
                        If Rom is reference to the LK license, thats installed and the web browser can be used. just wont allow me to install the bizhub marketplace on the touch panel itself.
                        • allan
                          RTFM!!
                          • 5459
                          Just referring to the error message. The requirements is the LK-101 V3 and UK-204. But the requirements on a support site mentions an i-option ROM to be installed with IWS 2.0 functionality in addition.
                          So is that a hardware or a software component.
                          Whatever
                          • emujo
                            • Jun 2009
                            • 3009
                            The ROM (along with all other components) would be updated by the firmware. There is nothing physical to replace here (outside of a possible bad system board or SSD). Ver 72 can be dropped back to ver 70, if your USB device is not working, try another one or format it and try again. I would try the softswitch change before anything else, your browser will still work. Emujo
                            • allan
                              RTFM!!
                              • 5459
                              Remember to remove the LK before doing this.
                              Whatever
