C451 Transfer Belt Drive Problem
  • mrfuser
    • 1617
    Re: C451 Transfer Belt Drive Problem
    Anyone have any other thoughts? I went back and replaced the gear assembly again with updated gears for transfer drive. It works perfect, but right away I could see it shred a little bit of the gear as flakes of white plastic flew down. I don't see anything binding to cause this and even put another belt assembly in. Any thoughts?
    Does anyone one have a pic of this installed to make sure I am not doing something wrong here?
      • 8165
      What sort of count is this old dog on?
      • mrfuser
        • 1617
        Total about 500k
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          #19
          Sounds like a worn bushing somewhere or something similar that is keeping the gears from meshing properly.
          "It's time to be CORRECT, NOT politically correct!!!"
          -The Truth
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • habik
            • 2013
            #20
            Try different Waste box and have a look at the waste box gear drive if it ain't stiff
            Firmwares HERE
            • tehrancopy.com
              Senior tech
              • May 2016
              • 6
              #21
              Change the Transfer Cleaning Motor . The motor shaft sometimes get worn out and it will cause damage to the gears .
              • matsan_offset@yahoo.com
                • Sep 2016
                • 43
                #22
                Originally posted by mrfuser
                Client complained of clicking/grinding sound and found that the Transfer Belt drive gear cluster was not staying engaged on exit side of belt area. We replaced that gear cluster and complete belt assembly and now it has come back again.
                Any ideas why?
                Thanks all!
                Hello, has your problem been solved? I have the same problem as yours.
                  did you read any posts past Mr Fuser's original post?
