Bizhub C652ds white dots in blacks
  • mntech
    • Aug 2010
    • 250
    [Dead] Bizhub C652ds white dots in blacks
    Hey guys,
    Black developer unit and drum unit were just replaced, the machine ran great for a few thousand clicks, now i have white dots showing up in just the blacks. CMY looks fine. There is no repetative pattern to the dots, and i dont see anything wrong with the drum or dev.
    Mag roller doesnt look like it has an contamination, and the problem doesnt change after running sky shots.
    I'm leaning towards dev unit as culprit, but i dont know why a brand new unit would cause such a problem.
    See examples.\
    Thanks,
    -MNTECH
    bizhub_c652ds.pdf
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C652ds white dots in blacks
    Check if the primary transfer current is set to default.
    Try switching on DEV AC BIAS.
    Whatever
    • Flash
      • 378
      Replace the transfer belt especially if you have been resetting the counter instead of replacing it.
      • mntech
        • Aug 2010
        • 250
        I believe the transfer belt has only been reset once, and is only around 25% over life, and surface looks great, no lines/grooves. One would think transfer belt would cause problems with all colors...not just black.
        I believe the primary transfer current is default but I will double check. what does the dev ac bias setting do?
        • allan
          RTFM!!
          • 5462
          Don't know exactly. Was told in training to switch it on it i get white spots on solids.
          could be developer unit or the drum. Check the K TCR value in state conformation level history 1.
          Whatever
          • mntech
            • Aug 2010
            • 250
            I don't ever recall seeing a setting called dev ac bias, is the setting you are talking about the dev bias choice?
            I never knew what that did, but I do know when that is turned on, the user no longer has the ability to do a calibration
            • copier tech
              • 8142
              Have you got any P codes showing?
              Dont rule out the ITB unit especially as you say it's way over life!
              Also the PTR that replace that with ITB
              • mntech
                • Aug 2010
                • 250
                Fixed!
                Changed primary transfer setting from 0 to -6 for black and the white spots went away.
                At first I increased the setting and spots got worse. Also the dev ac bias setting didn't make a difference so I left it off.
                Do you think I should replace the transfer unit or just run it with at -6 until there are more problems?
                Thanks for all the help
                • Laserbeam
                  • Aug 2011
                  • 152
                  Hi mntech,
                  yesterday I had exactly the same problem with a bizhub C552
                  First I replaced the drum without success, then the developing unit, but this phenomenon still occurs.
                  As you see in the attachments, one picture shows a halftone printout with a value 255, the other with value 70. On the halftone-printout (value 70) are much more white dots visible than in the other.
                  Tomorrow I will change the primary transfer setting value, as you described it.
                  Or is there in meantime already another solution?
                  • Laserbeam
                    • Aug 2011
                    • 152
                    Today I cleaned at first the metal contacts of the transfer roller, then I replaced the roller with an new one. The white spots were no longer visible. Now the halftone image in black is perfect!!!!
                    When I increase the primary transfer setting from 0 to +1 for black, only a few spots are visible. Now I changed the value to -1
