bizhub C454 - ADF jam code 23
  • MFPTech
    • 486
    Jam code 23 - "Misfeed detected. Remove paper as indicated by the circle"
    The circle is in ADF - Pickup rollers are down, no drive from the motor.
    Jam code 23 doesn't exists in the service manual - Replaced ADF Board - no change*
    Checked sensors and the document path again - ok
    Any ideas please?
    Thanks in advance!
    Sent from my SGH-I337M using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: bizhub C454 - ADF jam code 23
    Is that the jam code you get from service mode? should be like J66-XX
    Whatever
    • CraigW
      • Dec 2010
      • 417
      Print a management list to get more detailed #s about what is occuring.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        If that is the dual scan adf then check the cis cover and latch. If the latch sensor actuator is broke it will not clear the adf jam.
          • 23010
          Yes, jam removal prompts aren't terribly useful. What we need is jam codes from the management list. =^..^=
          • MFPTech
            • 486
            the jam code followed by CD010 error - took me 3 hours to do HDD format, download znd install movie data, a couple of firmware levels and restoring the address book and some default settings ... what an extensive labour machine not to mention that it was a coverage call. KonicaMinolta is the best copier to keep techs employed.
            • allan
              RTFM!!
              • 5462
              Is your machine running?
              Whatever
                • 23010
                It is really helpful to print off that management list. You can see all the errors ... even the ones that aren't displayed.
                For me the longest part of the process is downloading the firmware. Congratulations on your success. =^..^=
                • MFPTech
                  • 486
                  if i can print a management list then the machine is already fixed lol
                  • jmaister
                    certified scrub
                    • Aug 2010
                    • 755
                    summon the dead he says.
                    had the same code from customer. did as suggested to look at management list and found two occurances on different date.
                    And it was this jam code
                    66-13
                    for ADF 701, this can be due to ps2 malfunctioning. if you tape up ps3(reg sensor),you get code 24. (picture in manual seem very unintuitive)
                    Idling colour developers are not healthy developers.
