c352 unknown issue
  • blax
    • Mar 2013
    • 78
    c352 unknown issue
    hello guys, please check attached images, its M imaging unit photo test... never experienced this issue and we are tired trying to know if is the OPC, developer or what,,
    here in mexico we can not find original new IU, so we need to replace with new one OPC drum, developer and cleaning knife, always working fine but never experienced issues like those. anyone know what is happening?
  • jakani
    • Dec 2014
    • 147
    Re: c352 unknown issue
    i have almost the same issue with the C imaging unite !
    • blax
      • Mar 2013
      • 78
      do you know how to solve it?
      • chivozx
        • May 2014
        • 34
        Probably its a transfer problem.
        Probe whith other tipe of paper, change transfer values in service mode...
        • copier tech
          • 8165
          If it was the drum you'd have lines, I would say replace the developer & charge corona if you can get one.
          You could surely buy a complete new image unit on the internet?
          • francisco
            • Nov 2009
            • 168
            hello guys, please check attached images, its m imaging unit photo test... Never experienced this issue and we are tired trying to know if is the opc, developer or what,,
            here in mexico we can not find original new iu, so we need to replace with new one opc drum, developer and cleaning knife, always working fine but never experienced issues like those. Anyone know what is happening?
            [ATTACH=CONFIG]32082[/ATTACH][ATTACH=CONFIG]32083[/ATTACH]
            try to add some developer in (you can get in old pcus)
            • blax
              • Mar 2013
              • 78
              Francisco, what is PCUS?
              • blax
                • Mar 2013
                • 78
                do you know where can i buy developer? maybe an online store...
                is it necessary charge corona? we replaced the developer just by the top side.... or is needed open entire unit to put developer inside corona?
                • francisco
                  • Nov 2009
                  • 168
                  • Synthohol
                    Certified Konica Expert
                    • 5840
                    hello, the sample just looksw like contaminated DV likely from paper dust.
                    you need a whole IU, you cannot vacuum any developer, its not like kyocera there are metal particles in the DV unit mixed with toner, you cannot seperate.
                    best you can try is running 50 or so of the halftone patterns at 255 like you provided. you will see the white spots dissapate. you will go through some toner but it may flush the contamination out enough to get by.
                    • jakani
                      • Dec 2014
                      • 147
                      i solved the problem by changing the transfer belt
                      • Ciomu
                        Senior
                        • Aug 2015
                        • 4
                        1. Developing unit may be doing this
                        2. No developer is bought separately
                        3. Expired or toner for use can also cause this.
