Bizhub C224e ghost image
  • photocopier.technician
    • 27
    Hi
    I am having a problem with a Bizhub C224e. When printing there is a part of the print that repeats itself on the page. As per experience i thought it was the fusing unit but when i stopped the print before it gets into the fusing unit the problem is already there and also the fusing unit rollers are clean. So its not the fusing unit.
    Then i checked the drum units all of them seem ok. Even tried to swap cyan with magenta but still same problem. When i removed the transfer belt just after a copy i can see the repeated image on the transfer belt.
    Cleaned the lasers and the drum corona
    No error codes or warnings
    I attached a sample for better understanding the problem.
    Please give me your opinion
  • Max
    • Oct 2011
    • 555
    Re: Bizhub C224e ghost image
    Try the belt 1st. looks like its not being cleaned
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      all 4 erase lamps working properly ? Drum grounding check out ok ?
      that repetitive image defect is drum spacing.
      Possible run away HV control issue too / defective hv board.
      • yianni
        • Jan 2013
        • 42
        I've never seen repeating white text. Try printing another pattern. For example fill 50% of a color and inside it black, white, cyan, magenta and yellow text.
        • allan
          RTFM!!
          • 5462
          Is the paper printed LEF or SEF? long side first or short side first.
          Do you get this defect from the demo page??
          Whatever
          • Synthohol
            Certified Konica Expert
            • 5808
            are the erase LEDs working?
            • adecanmin
              • Oct 2010
              • 298
              I had this exact problem. Tried replacing everything mentioned. What fixed it for me was using a different driver. They were using a PCL driver, printing from an Adobe program on an XP box. I tried an PS driver and the problem was fixed. What's strange is the machine worked fine for a year and half with no issues with the previous driver.
