Konica C280 error P-21
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    As a Ricoh engineer, I'm steadily learning the Konica machines and have a C280 which presents error P-21.
    I understand this is an ID read error of the calibration patches on the transfer belt.
    This machine had a yellow colour alignment issue which I managed to resolve (more or less) by adjusting the yellow registration in expert adjustment.
    Im not totally satisfied that colour reg is the best it can be as I've never had to manually adjust on these.
    I have swapped the transfer belt with a used belt and run image stabilisation and gradation.
    I have cleaned both ID sensors and swapped the drums round and also reset the drums with reset chips.
    Solid colour prints from service mode ensure me that the drums and devs are fine, nice and solid....
    I have cleaned the laser windows with the white sticks under the drums.....
    Im at a loose end now and have ordered a brand new transfer belt but wanted to see if anyone could help or share their experiences with this error?
    Many thanks
  • copier tech
    • 8182
    Re: Konica C280 error P-21
    This is usually caused by a worn ITB unit or dirty ID sensors, also drums past life can cause this.
    After you have replaced the new ITB unit run initialise+gradation.
    You can have a P-21 error & it not cause any real problems, however it does require you or the user to run a regular gradation adjustment.
    • allan
      RTFM!!
      • 5462
      Coming from RICOH color machines these C280 machines are a joy to work on.
      Check in service mode under State Confirmation system 1 what the IDC values are.
      There is two sensors to check the patches 2 colors on each side.
      If those values are not the same IDC1 and IDC2 the belt could be bad on one side.
      Under system 2 you can see the bare surface reflective values of the belt.
      If you don't get a the right value under system 2 the sensor shutter could be faulty.
      Whatever
      • jonbonse
        • Jun 2009
        • 737
        Thanks!
        Under State Confirmation, Level History 1, IDC1 value is 1.62v and IDC2 is 2.91v. I hear the shutter open as I press enter.
        In Level History 2, IDC Sensor Adjust 1 and 2 are both 255. . . . (pics attached)LH1.jpgLH2.jpg
        • allan
          RTFM!!
          • 5462
          Is the transfer belt a matt color on the sides .
          Whatever
          • jonbonse
            • Jun 2009
            • 737
            Not too sure what Matt colour is but have included pics. . . .ITB-2.jpgITB-1.jpgITB-3.jpg
            • mo0651
              • 1054
              We had a brand new transferbelt cause this error, if you have one to swap I would try it.
              • JR2ALTA
                • Feb 2010
                • 2033
                are we talking about an oil can error?? IGNORE IT!
                • jonbonse
                  • Jun 2009
                  • 737
                  Unfortunately can't as the colour misalignment has returned!
                  • allan
                    RTFM!!
                    • 5462
                    Originally posted by jonbonse
                    Not too sure what Matt colour is but have included pics. . . .[ATTACH=CONFIG]32185[/ATTACH][ATTACH=CONFIG]32186[/ATTACH][ATTACH=CONFIG]32187[/ATTACH]
                    Does that yellowish color on the left could cause your problem. Does that wipe of with a cloth?
                    I think a new ITB will fix your problem.
                    How many prints on it??
                    Whatever
                    • jonbonse
                      • Jun 2009
                      • 737
                      No it won't clean off.... It's done 367k.......
                      i I have a new ITB on order for delivery Monday so I hope it does the trick!
                      • allan
                        RTFM!!
                        • 5462
                        Have you changed development units yet. When last did you change drums? There is something shady about that yellow.
                        Whatever
                        • jonbonse
                          • Jun 2009
                          • 737
                          I haven't replaced the devs but had them all out and don't look too bad....(pic of yellow attached)
                          I have tried swapping the drums and have reset the chips.....
                          • 3boydad
                            • Aug 2015
                            • 27
                            are you getting this by touching the oil can icon? which it sounds like. it's just to run drums past counters. ignore it.
                            • jonbonse
                              • Jun 2009
                              • 737
                              yes but the colour reg is out now.....
