Konica C280 error P-21
  • Synthohol
    Certified Konica Expert
    • 5855
    #16
    Re: Konica C280 error P-21
    try this...
    ; "> 1. Call the Service Mode to the screen.
    2. Touch these keys in this order:
    [Machine] [Skew adjustment] [Print Head Skew Reset].
    3. Touch the start key and execute the Print Head Skew Reset.
    if the shutter works and the IDC sensor is reading the proper patches this might work for you.
    also is the machine up to date with firmware?
    G00-D2 is the latest.
    • allan
      RTFM!!
      • 5462
      #17
      Originally posted by 3boydad
      are you getting this by touching the oil can icon? which it sounds like. it's just to run drums past counters. ignore it.
      Originally posted by Synthohol
      try this...
      Life codes starts with L like L-4.
      Skew adjustment will only work if the machine can read the patch. Currently his machine is not reading the patch because the patch is camouflaged in yellow.
      That dev tank should be ok.
      Whatever
