Bizhub 283 with C-D272
  • Garp
    Technical Manager
    • Mar 2015
    • 51
    [Error Code] Bizhub 283 with C-D272
    Hello all,
    could someone help me out please?
    I cannot find any info about this error code on a BH 283: C-D272.
    When I switch on the copier it calls for SSD format but the buttons are numb, and about 10sec later the code comes up. Screen and buttons are still dead, no noise from th machine, like frozen.
    HDD, cables and connectors checked.
    I have the SM, but no info related can be found in it.
    Any _real_ help would be appretiated.
    Cheers.
    • 14791
    Re: Bizhub 283 with C-D272
    Originally posted by Garp
    Hello all,
    Cheers.
    Straight from the service manual.
    i-Option activated and
    additional memory and
    HDD not installed
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      turn off the ioption in tech rep mode
      • HoonBoy
        • May 2011
        • 130
        If i recall correctly, you can only format SSD if HDD is set too "not installed". SSD format is availible where format HDD was...
        • Garp
          Technical Manager
          • Mar 2015
          • 51
          HDD not installed
          Cheers mate, I don't know what am I looking at here, but I can't see this code in the SM of the copier. Thanks, anyways.
          • Garp
            Technical Manager
            • Mar 2015
            • 51
            Nope. After start-up "Format SSD" (or so) comes up on the screen but all keys are dead also the screen not responding to touch. After 10sec more it produces the error msg. I got the error description above, so I'll get this back on the right path soon.
            Thanks for all the answers!
              • 14791
              Are you looking in the correct manual? This is from the service manual for a Konica Minolta Bizhub 283.
              CD272 i-Option activated and
              HDD not installed
              • While the i-Option is activated, the additional
              memory included in UK-203 and the
              HDD are not installed.
              Cheers!
              This a service bulletin I found.
              CD272 after disabling the HDD for test purpose and switching OFF/ON the MFP. Unable to enter the Service Mode to enable the HDD again, which is necessary to get rid of the trouble code.
              Workaround/Fix
              CAUSE: Incorrect procedure.
              SOLUTION: Please follow these steps in sequence.
              1. Switch OFF the MFP
              2. Remove the optional i-Option memory (UK-203).
              3. Switch ON the MFP and enter Service Mode.
              4. Enable HDD.
              5. Exit Service Mode and switch OFF the MFP.
              6. Reinstall the optional i-Option memory.
              7. Check MFP functions.
              • Garp
                Technical Manager
                • Mar 2015
                • 51
                sorry i was on holidays.
                Well, shame on me: the error code section of the manual I got was sent as the correct one - it wasn't.
                Cheers for the correct descriptions and the bulletin!
                It'll be fine now.
                Thanks once more...
