C224 QUALITY PROBLEM
  • karim-tech
    • 47
    hey every body some help plz
    i have a quality problem with a KM c 224
    for the test pattern shown in the first picture is with 2 level
    the first 4 colors wirth the 255
    and the second with 100
    the problem is too light in the side with the red circl for the 4 colors
    i have changed the transfert belt the fusing unit also the k DRUM but problem persisted
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C224 QUALITY PROBLEM
    since its all 4 colours I'd be looking at the second transfer roller first of all, is it pressing properly against the belt ?
    Have you stopped the machine mid paper feed to see if the image is formed perfectly on the belt ? if it is, you can be assured its a second transfer issue.
    • karim-tech
      • 47
      thx
      EarthKmTech
      for the replay
      i have changed the second transfert also and the problem persiste
      i stopped the machine to creat a missfeed paper to check out the latent image created on the transfert belt and the image was with the same problem
      thanx again
        • 14606
        Originally posted by karim-tech
        thx
        EarthKmTech
        for the replay
        thanx again
        Did you clean the printheads?
        • karim-tech
          • 47
          thx for the replay
          yes i did for the 4 printheads
          let me tell you that the problem is in the 4 test colors
          if it was the printheads maybe will be just in one color
          thax again
          best regards
          • emujo
            • Jun 2009
            • 3009
            Have you double checked to ensure the shipping locks were removed from both sides of the X-fer roller? I've seen this bite more than a few techs thinking that since the string came out, the lock must be out also. If the image is being laid on the xfer belt the same way, then the issue has to be related to the print head, or x-fer belt. Emujo
            • kingarthur
              • 1338
              is the m/c level...
              • allan
                RTFM!!
                • 5462
                I have a similar problem on a C280 all seems fine second transfer and ITB replaced the machine is level the drums and DEV unit are all good. I changed the paper to SEF and the call is gone for months already.
                Have you tried adjusting the transfer currents??
                Whatever
                • mo0651
                  • 1054
                  We had a c454 non e model with a similar quality issue. We had a bad printhead.
                  • allan
                    RTFM!!
                    • 5462
                    That is one of the few things i did not change?? I will try that when the call comes back...
                    Whatever
                    • gordonu10
                      Have you tried cleaning the IDC sensors under the transfer belt?
                      • Elmo
                        • Feb 2010
                        • 541
                        what copy count have the developers done
                        have you tested a different developer unit
                        from the comparison pics all pages looks weak not just the edge
                        I Used To Live To Fix Things Now i Fix Things To Live
                        • Synthohol
                          Certified Konica Expert
                          • 5809
                          I've seen similar issues when the floor tilts the copier towards the wall so all the DV bulk is in the middle to rear.
                          Put a level on the platen glass and see if it's off kilter.
                          • DelawareJim
                            • Jan 2008
                            • 65
                            Check the 2nd transfer assembly housing. In perticular, the 4 springs and 2 tabs that hold it onto the frame. Simply remove the whole assembly and reinstall making certain that the 2 tabs and all 4 springs go where they are supposed to go.
