951 CQ weird
  • yakyitz
    • 245
    951 CQ weird
    The first pic is the original the second is the copy. You can obviously see the heavy background on the top half, but if you look closely you'll see that the bottom half of the image is repeated/ superimposed on the top half. The drum and Dev both have 750k, the charge coronas and grid have 220k. Any ideas?
  • allan
    RTFM!!
    • 5462
    Re: 951 CQ weird
    http://www.copytechnet.com/forums/konica-minolta/105434-bizhub-press-1052-interesting-print-anomalies.html?highlight=1052
    Whatever
    • SwisSeV
      • Jan 2016
      • 307
      Re: 951 CQ weird
      With counts like that, the machine should be up for PM right? Might as well compete the PM and see if the problem persists.
      • allan
        RTFM!!
        • 5462
        Re: 951 CQ weird
        I am having trouble uploading images.
        Well that was what the prints looked like.
        Whatever
        • yakyitz
          • 245
          Re: 951 CQ weird
          Ok I'll admit I've had this same issue on this machine. Replacing charge wires and grid solved the issue then. That was 220k ago. I could order and replace again the charge components and see if it solves the issue, but I'd like to get to the root cause. The machine is only about 2 years old and has over 3 million copies. I don't want to have to come back every 200k to replace coronas. We have at least 10 of these in the field.
            • 23009
            Re: 951 CQ weird
            Just powering down may make it go away. If it does, you'll probably need the LED printhead. =^..^=
            • yakyitz
              • 245
              Re: 951 CQ weird
              Thanks Blackcat, I had powered it down to take a look at the condition of the charge unit, which looks okay. It didn't disappear. I'm going back tomorrow to replace charge wires and grid. I'll update afterwards.
              • iceman490
                • May 2014
                • 46
                Re: 951 CQ weird
                Im with blackcat on this one just had this issue maybe a month a go same quality cleaned the charge and reseated connections all was well for 2 days replaced the led printhead all is well.
                Sent from my SM-G920V using Tapatalk
                • yakyitz
                  • 245
                  Re: 951 CQ weird
                  I replaced the charge wires and grid. It didn't help this time. Thanks for the replies. I'll order the head and post results.
