Konica Minolta C250 Scan to Email
  • kcroto
    • Nov 2015
    • 7
    I have repurposed a C250 BIZHUB. The last option i am trying to setup is Scan to Email. I am trying to use a gmail account. I have researched the web but somewhere I have an error. I am pretty sure I can get out on the web as I pinged smtp.gmail.com and got a good reply. I have the same email address in for the administrator and machine as I do the gmail account. I think I have the correct ports, I have SLL?????
    Any thoughts? It sounds too simple to make an error.
    Thanks,
    Keith
  • kingarthur
    • 1369
    Re: Konica Minolta C250 Scan to Email
    when you input the email addresses, where it says "input the machine address", put the email address where it says "device name" and not where it says "email address" I've only set it up once as an experiment, and that was the mistake I kept making, until I read it properly
    • wseyller
      • Sep 2012
      • 1129
      Make sure you turn on "less secure apps" in the Gmail security settings.
      Sent from my XT1254 using Tapatalk
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5849
        here ya go
        • kcroto
          • Nov 2015
          • 7
          I tried this, or corrected it but I had no success
          • kcroto
            • Nov 2015
            • 7
            I suspect that if everything else was correct that this would have been an issue. I did try to setup my outlook client to work with Gmail and discovered that with the 2 step process I use I needed to provided a onetime password which worked well for outlook. I tried this for the konica and had no luck.
            • kcroto
              • Nov 2015
              • 7
              Originally posted by Synthohol
              here ya go
              Thank you for your input. I went through this and still no luck.
              • Synthohol
                • Mar 2016
                • 5849
                What is the error code? You may have to turn on display errors for network in adm8n mode.
                • kcroto
                  • Nov 2015
                  • 7
                  So as I said earlier I decided to ensure the settings I was using for gmail were correct by adding a gmail account to my outlook client. And I discovered that the two step authentication was stopping me. I could add and use an "App Password" for outlook but it did not work for the Konica.<br>
                  <br>
                  I punted on gmail and worked on my outlook.com account. Again I tested it with my outlook client, and it works correctly. However when I put the same settings in the konica I still get an error.<br>
                  <br>
                  I did try the ping test through the Konica to smtp.gmail.com and it was successful. So I can reach the internet.<br>
                  <br>
                  I took a screen shot of the settings via the webclient.<br>
                  <br>
                  Any more thoughts would be welcome.<br>
                  <br>
                  Keith
                  • Synthohol
                    • Mar 2016
                    • 5849
                    first off disable POP, and pop before smtp. no reason for it.
                    what is the error after a failed send?
                    also the email settings in the pic have nothing to do with gmail unless it was just a ping test.
                    • kcroto
                      • Nov 2015
                      • 7
                      I did disable the pope and pop before smtp. The error I get from the job history is failed to connect to server. Unless there is another error location that I have not found.
                      Yes I pinged gmail because outlook will not respond to a ping.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        Try using the isp outgoing mail server?
                        Sent from my SM-G900I using Tapatalk
                        • Synthohol
                          • Mar 2016
                          • 5849
                          didnt outlook move to smtp.live.com?
                          • kcroto
                            • Nov 2015
                            • 7
                            I did try the smtp.live.com and had no better luck with it. I went back and forth on the correct url, however the latest info appears to be the smtp-mail.outlook.com.
                            Regardless I took the suggestion to use a mail account from the ISP and that worked. The ISP is comcast using roadrunner web mail.
                            So thank you all very much for your help.
                            Keith
                            • gerryproulx
                              • Mar 2015
                              • 24
                              do you have a DNS server set to resolve that name to an address? Gmail doesn't use port 25 try 587, there is a user but no password in the authentication
