Bizhub C220 won't start up
  • Arteminium
    • Apr 2016
    • 8
    After removing, cleaning, and reinstalling the ADF and replacing the paper feed tray, I plugged the power cable back into the machine, and turned on the primary power switch, the machine failed to successfully start. The data transfer light flickers for a second, then turns off, and I can hear the fan running, but that's it. I've tried to diagnose the problem every way I know how, but with a grand total of 2-3 months as a technician, that didn't take long.
    Any and all help would be greatly appreciated.
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C220 won't start up
    Did you unplug the network cable before starting.
    Does the hour glass appear.
    Does the fuser get hot?
    Welcome to the world of frustration.
    Whatever
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      Common issue, cleaning, switch on - nothing happens. After reloading the firmware it was running again. Had this ca. 8 times.
      Greetings...
      • DigiMan
        • Jan 2013
        • 262
        "I've tried to diagnose the problem every way I know how"
        Share it with us and explain
        I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
          • 23008
          What happens if you disconnect the DF again? Does it power up? =^..^=
          • Synthohol
            Certified Konica Expert
            • 5839
            i know this is a stupid question, is the Sub Power switch on?
