C451 w/ problem of c3423
  • verchez
    • Aug 2025
    I have c451 with error code c3423 which means problem in heater unit pressurizing side. I am able to reset it but after a week it happened again.
    What i can i do to finally solve it?
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    How many copies?
    Likely, a new fuser....
    • verchez
      c3423
      The machine is just a week old from installation when the first code c3423 appeared. Anyhow i will try to swap the fusing unit to other c451 machine just to try.
      • Albonline
        • Sep 2008
        • 1153
        is supply voltage correct? (wall outlet)
        • verchez
          voltage
          Yap the machine is 110 volts connected to a voltage stabilizer.
          • bigmark
            • Sep 2008
            • 39
            dedicated outlet
            another thing to check, along the lines of the wall outlet - is the outlet a dedicated 20amp outlet. many people are just placing 20 plugs on a 15amp circuit, or using a pig tail to connect to wall.
