bizhub C284 scan to email error
  • Reed
    • Feb 2011
    • 261
    trying to set up a bizhub C284 scan to email. Doesn't matter which smtp server I am trying to use I alway get a 'server connection error" the error is 107 which according to the book is " the socket is not connected" How do I fix this?
    thanks in advance
  • copier tech
    • 8236
    Re: bizhub C284 scan to email error
    OK, start with the basics, do you know your DNS & gateway setting are correct? if you're unsure turn on DHCP let the machine pick this info up & try again.
    As a test I use a gmail account to test scan to email smtp.gmail.com etc
    • Reed
      • Feb 2011
      • 261
      yes I set the network card to DHCP and also have reset the network card a couple times so that it would pick up the proper DNS and Gateway
      • Synthohol
        Certified Konica Expert
        • 5912
        can you successfully ping anything in the outside world from the copier?
        are you using gmail? the non e series has issues now since google changed their security. there is firmware to kind of fix this and trick the copier to thinking its an e series with the newer version of security.
        Solution
        CAUSE: Google has made SSL Security changes from TLS 1.0 to TLS 1.2. Currently, our non-4e products only have TLS 1.0 support with base firmware GXX-72.
        SOLUTION: There is a workaround available until an official Base Level Firmware is created with TLS 1.2 support.
        Upgrade the MFP with two specific firmwares to allow it to have the same functionalities that a 4e series has (GB2-K5). This is a 2-step process and a softswitch change is required.
        IMPORTANT: Please precisely follow the steps below or the MFP may become inoperable.
        1. Before updating the machine firmware to GB0-A9
        a. Set Software Switch 25 to HEX 20.
        b. Install GB0-A9 firmware.
        Note: If the bizhub is not updated to GB0-A9 firmware, the update to GB2-K5 will not install successfully.
        2. Version GB0-A9 A1610Y0-F000-GB0-A9.exe (for Web Browser LK-101v3 support)
        3. Version GB2-K5 for bizhub C554 series and C364 series A1610Y0-F000-GB2-K5.exe
        CRITICAL ITEMS TO BE ADDRESSED (PLEASE READ)
        1. Back up the Network Settings, Address Book, and Remote Access (vCare) settings. These values will be initialized during the upgrade process.
        a. Export the Network Settings, Address Book, and Remote Access settings to a USB stick using the External Memory Backup function
        b. If using Firmware versions GP7-65, GPK-68, GPR-68, GP4-70, or GPC-70, check the TCP/IP Address and DNS Server settings manually and write them down.
        2. Determine whether or not Voice Data exists. If it is present, delete it.
        a. Enter Service Mode.
        b. Navigate to System 2 -> Next Page.
        c. Press Install Data. If Voice Data exists, highlight it; then press Delete.
        d. Press End -> Exit.
        e. Turn the machine OFF.
        3. If a Code CE301 is indicated
        Code CE301 may occur in two specific environments.
        • Serverless Ubiquitous Print (LK-114)
        • Thin Print (Firmware version GPS-65)
        If this occurs:
        1. Enter Service Mode.
        2. Navigate to System 2 -> Software Switch Setting.
        3. Set Switch 156 to HEX 08; the press Fix. The HEX value will return to “00” automatically.
        4. Reboot the machine.
        5. Update the machine firmware to GA0-A9.
        b. Install GA0-A9 firmware.
        6. Set Software Switch 25 to HEX 60 (Function version 7).
        a. Turn the machine ON and let it boot normally.
        b. Enter Service Mode manually.
        c. Navigate to System 2 -> Software Switch Setting.
        d. Set Software Switch 25 to HEX 60.
        e. Press Fix; then wait for a soft beep to indicate that the value has been set.
        f. Press END.
        g. Turn the machine OFF.
        7. Install the version GB2-K5 firmware that corresponds to the MFP model.
        a. Insert the USB stick into the service port.
        b. Turn the machine ON and wait a few minutes for it to boot into Service Mode.
        c. Press the Start button, which will begin flashing.
        d. Wait while the firmware is installed. When it is done, the Start button will be steady blue (not flashing).
        e. Turn the machine OFF and remove the USB stick.
        8. Install the Movie Data and Voice Data.
        c. Navigate to System 2 -> Next Page.
        d. Select Install Data.
        e. Insert the USB stick containing the Movie Data and Voice Data into any USB port.
        • Movie Data
        - Press Movie Data. Be sure to deselect any other option that may be highlighted.
        - Press Set.
        - Press the Start button and wait for the data to be written.
        - When finished, the Movie Data version will be displayed.
        • Voice Data
        - Press Voice Data. Be sure to deselect any other option that may be highlighted.
        - Press Set.
        - When finished, the Voice Data version will be displayed.
        f. Press END.
        g. Remove the USB stick and exit Service Mode.
        h. Turn the machine OFF/ON.
        9. Install the Loadable Driver (only if a card reader such as the AU-201H is installed). Follow the installation directions that accompany the Loadable Driver.
        10. Restore the Network Settings, Address Book, and Remote Access (vCare) settings which were backed up.
        a. Import the Network Settings, Address Book, and Remote Access settings using the External Memory Backup function.
        b. If the Network Settings were written down, enter them manually.
        11. Reinstall bizhub Marketplace, if applicable.
        12. Update the drivers on users’ computers to the appropriate version to work with this updated machine firmware.
        13. If applicable, perform the following steps to have the MFP communicate with the vCare system.
        b. Press the “CS Remote Care” button twice.
        c. Press the “ID Code” button.
        d. Enter the Tech ID number (must be 7 digits).
        e. Press the “ID Code” button.
        f. Press the “Detail Setting” button.
        g. Press the “Date & Time” button.
        h. Enter the current date and time (24-hour format).
        i. Set the time zone; then press the “Set” button.
        j. Press the “Basic Setting” button.
        k. Press the “Initial Transmission” button.
        l. Press the “Initial Transmission” button in the lower right corner. The status will display “Completed” in the upper left corner of the screen.
        Technical Notes
        This is only a temporary solution. Ultimately a new base firmware and all future base releases will contain TLS 1.2 support. The request will be for all the non-4e and C552 series machines.
        • Reed
          • Feb 2011
          • 261
          I have tried using a non gmail smtp. I tried using the one provided by the local internet provider and I even tried a yahoo. Both error out
          • Synthohol
            • 5912
            Most cable internet isps block port 25.
            Can yoy ping the outside world from the copier?
            • Reed
              • Feb 2011
              • 261
              how do i ping the outside world from the copier. I am sure I have seen this somewhere while in the admin settings but can't remember where to find it .. thanks
              • Synthohol
                • 5912
                IiRC admin network expert settings ping
                Verify the gateway and dns are correct
                • 1twig
                  • Apr 2013
                  • 12
                  The problem could be something as simple as the administrators email has to be the same as the account or id.First of all what type of email scanning are you doing?
                  1twig
                  • 1twig
                    • Apr 2013
                    • 12
                    Here's the setup I used to scan to yahoo smtp account.
                    1twig
                    • Reed
                      • Feb 2011
                      • 261
                      1twig
                      Q0
                      Sent from my SM-G920T using Tapatalk
                      • Reed
                        • Feb 2011
                        • 261
                        1twig
                        Tried those settings. Still no luck
                        • Reed
                          • Feb 2011
                          • 261
                          I tried smb scanning to a folder and still no luck. Which leads me to believe a security setting is turned on. BTW.. I was able to ping yahoo from the copier.
                          • Reed
                            • Feb 2011
                            • 261
                            Well I actually got it to scan to a folder. Just can't get the scan to email
                            • Reed
                              • Feb 2011
                              • 261
                              finally got it working. Had to update the firmware for the scan to email to work
