BH500 vertical lines PRINT ONLY
  • GeorgeK
    • Sep 2008
    • 23
    [CQ] BH500 vertical lines PRINT ONLY
    Appreciate your help.
    On a bizhub 500 I have the intermittent vertical lines (as per attachment) only in printouts.
    Copies are just fine.
    Any suggestions ?
    Thanks in advance for your help.
    TECHNICIAN noon. (tek~nish~uh n)
    A person who fixes the mistakes made by engineers.
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: BH500 vertical lines PRINT ONLY
    i would check the drum surface, can you print a blank 11x17 or A3 to see if the marks repeat?
    • DigiMan
      • Jan 2013
      • 262
      Had the exact same thing on a bh 283.
      No (obvious)marks on drum but changing the drum resolved the issue.
      After 20-30k exactly the same,only guess was that the dev tank was causing it.
      Changed the drum again and haven't had a problem since.Weird.
      Try to swap a drum from another machine if possible.
      I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
      • bennier2004@yahoo.com
        After checking drum.....i would check the laser assembly
