C350 with booklet finisher
  • rasman67
    • May 2025
    I have a C350 that I installed but the folding doesn't show up as an option. If I place the finisher on a C450 it shows the folding option. What do I have to do to get this feature to work on the C350.
    Thanks in Advance
  • WaveyDavey
    • Sep 2008
    • 60
    is it just the folding feature or does the finisher not show at all?
    • rasman67
      Yes I have The hole punch and stapling features
      • WaveyDavey
        • Sep 2008
        • 60
        do you have a duplex unit fitted? booklet will not appear if you don't
        • rasman67
          yes it has the duplexer
          • WaveyDavey
            • Sep 2008
            • 60
            which model finisher is it? FS603?
            • Specilist KVN
              • Sep 2008
              • 79
              Thanks in Advance
              If the finisher shows up in the driver as an installed option then it is in your settings.
              Have you tried different stock sizes and weights?
              If it is not showing in the driver, configure the 2-way communication or add the finisher as an option.
              Also, you need to exit the program sometimes when reconfiguring the driver.
              • WaveyDavey
                • Sep 2008
                • 60
                yes is this folding option not available on the desktop or not available on the control panel?
                • Albonline
                  • Sep 2008
                  • 1136
                  what modle finisher? c350 uses fs601 c450 uses fs603.
                  • WaveyDavey
                    • Sep 2008
                    • 60
                    thats where I was going
                    • rasman67
                      I'm using an fs-601 and it is not showing up on the op panel, but the fs-601 will show the fold/staple mode on the c450 op panel just fine.
