c-5603 on 554e
  • splblazer91
    • Jul 2014
    • 204
    c-5603 on 554e
    Anyone have a fix for this?
    We have replaced the FSB, Expansion Board and Print Head unit. Still no luck.
  • mphile
    • May 2011
    • 29
    Re: c-5603 on 554e
    Good day you all,
    I have got the same problem and mine is a bit different, I have gone to replace Cyan Dev Unit and BOOOOM!! when I turn on the machine it comes with error code C5603. Now machine wont respond even if you re-install the old unit. Please note the machine was not asking for dev unit to be replaced, I had to replace because of copy quality. Any help will be appreciated.
    • splblazer91
      • Jul 2014
      • 204
      Re: c-5603 on 554e
      Mine ended up being the PRCB.
      • javier4065
        • Feb 2007
        • 251
        Re: c-5603 on 554e
        Hello friend where is the front board and the print control board because I have de same problem c5603 First display says c2563 thanks in advance
        • Synthohol
          Certified Konica Expert
          • 5799
          Re: c-5603 on 554e
          FSB is behind the plate (3 screws) that the DV units hide behind.
          also...
          3.10.12 C5603
          (1) Contents
          Trouble type Expansion control board communication error
          Trouble code C5603
          Rank C
          Detection timing Communication error is detected in expansion control board.
          Trouble isolation -
          Relevant electrical parts • Expansion control board (EXCB)
          • Front side board (FRB)
          • PH unit
          • Printer control board (PRCB)
          (2) Procedure
          Step Action Control signal Location of electrical components
          1 Reboot the machine. - -
          2 Check the connector between EXCB-PRCB for proper
          connection and correct as necessary.
          3 Check the connector between FRB CN5-PH unit for
          proper connection and correct as necessary.
          4 Check the connector between FRB CN2-PRCB CN8
          for proper connection and correct as necessary.
          5 Replace EXCB - -
          6 Replace FRB - -
          7 Replace PH unit - -
          8 Replace PRCB - -
          • javier4065
            • Feb 2007
            • 251
            Re: c-5603 on 554e
            also...there is not way to reset this code maybe a service program thanksh
            3.10.12 C5603
            (1) Contents
            (2) Procedure
            5 Replace EXCB - -
            6 Replace FRB - -
            8 Replace PRCB - -
            [ATTACH=CONFIG]37085[/ATTACH][ATTACH=CONFIG]37086[/ATTACH]
            there is not way to reset this code maybe a service program because tje first problem was changing developer thanks
            • Synthohol
              • 5799
              Re: c-5603 on 554e
              turn it off with the main switch inside the door, hold down panel reset while turning it back on, close the door and hold the reset until you see a black dot in the upper right. you can let go.
              next in a few will be a box that says trouble reset. touch it, it should say OK.
              power off and wait 10 full seconds and power up.
              let us know.
              • kim171170
                • Dec 2024
                • 1
                stesso problema ho resettato con procedura ....ma niente
