Konica 7145 HDD Error
  • Hoshal
    • Sep 2008
    • 6
    I'm trying to setup a scan to box on a Konica 7145, with an HDD installed. I've formatted the HDD and it shows the correct capacity and everything, but when I create a User Box and try to complete a scan, the data light stays lit and never goes off. When I check the Job List during a scan, it says Scanning, Converting, Waiting, Processing, Waiting, then just disappears.
    When I check the capacity after a couple scans, it shows a few MB used. When using the Pagescope Box Operator, it can never connect to the machine. I've tried bypassing everything and going straight from a laptop right to the machine, and nothing. Printing works with the IP address though.
    Any ideas?
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    If the HDD is new to the machine, you may need a firmware upgrade before this machine can work with a higher capacity HDD than it was originally configured for.
    It's a start.
    • DocuSystems
      Service/IT/Integrator
      • Jan 2007
      • 54
      I agree, check the firmware. There was an issue with older firmware causing premature failure of the HDD. I had one which killed two drives before I upgraded.
      • Albonline
        • Sep 2008
        • 1151
        firmware deals with hdd spindown when idle and 40gig size limit
