Km 421 administrator password locked
  • marvin_PL
    • Jun 2012
    • 24
    Hi.
    Machine bh 421 could not enter to admin mode . password 12345678 doesn't access. i can't change it from service mode, machine freeze after enter code.
    Machine version is 21, I read some posts about the problem and I need files from compact flash card from working machine version 13.
    Maybe someone can send me it..
    Best regards
    • 23009
    Re: Km 421 administrator password locked
    It seems to me that there were only 6 digits to the 421 Admin password. Try 6 digits. =^..^=
    • Synthohol
      Certified Konica Expert
      • 5848
      Problem
      Unable to access Administrator Mode. Password fails. When attempting to change the default admin password the machine will also lock up.
      Solution
      CAUSE: Information is corrupt on the CF Card.
      SOLUTION: Please perform the following procedure depending on model.
      • For the bizhub 361/421/501
      1. Load Base CF Card Recovery Firmware.
      2. Install firmware version 11 or 13 via USB drive.
      3. Enter Service Mode.
      4. Enter Stop, 0, Clear.
      5. Change the default admin password to 12345678.
      6. Exit Service Mode and verify that you can enter Administrator Mode.
      7. Proceed to flash to the latest version of firmware.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Originally posted by Synthohol
        Problem
        Solution
        I also had this issue on the old bizhub 601 /751's it was a dead give away the cf was corrupted.
        • Synthohol
          • 5848
          i disliked anything to do with the CF cards, i started doing firmware via FTP on my laptop instead.
          • INKATEC
            • Jun 2010
            • 6
            No my friend, are 8.
            Enviado desde mi ALE-L23 mediante Tapatalk
            INKATEC
              • 23009
              Yeah, I checked. =^..^=
              • Kapral
                • Oct 2012
                • 44
                I had the same problem, and I have the v. 13 firmware .
