Fail Reset in Minolta C 451
  • Andre Luis dos Santos
    • May 2016
    • 23
    Hello , I need a big help of you . I have a C451 Minolta and she is asking the exchange of Fusion .The merger can not be reset in the technical mode. I've tried to put a fuse 80 mA . What can I do to reset the fusion drive ?
  • allan
    RTFM!!
    • 5462
    Re: Fail Reset in Minolta C 451
    U need a 63mA slow blow fuse. Its all about the time it takes to blow the fuse.
    Did the 80mA fuse blow out?
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5820
      allan is correct, a .063A (1/16 amp) pico fuse is what is needed.
      years ago we used an analog corona wire about an inch long and that used to work 3 outta 5 times.
        • May 2016
        • 23
        I tried to reset the corona wire , without success. The fuse of 0.63 A not found in the city to buy. Any other suggestions? Thanks to those who tried to help .
          • May 2016
          • 23
          • Tech Helpdesk
            • Jul 2015
            • 112
            Check ICP2 on the Printer Control Board it may be blown. If you still have drum refurb kits for the DI250 or DI2510 they have pico fuses in the box, use one of those
            • Synthohol
              • 5820
              Not to sound harsh but you can always just replace the fuser with a new one. If the customer has a service contract they have been paying for one along the way.
              If you cannot get the correct fuse you dont have many options.
              Also when using a corona wire you must use one from an old analog copier. The corinas for digital machines are much tougher and will not "pop"
              If there is an oil roller in the fuser its likely dried out and will only cause a call-back later when the rollers start to collect toner.
                • May 2016
                • 23
                I found a fuse 0.3 The right also ?
                • Synthohol
                  • 5820
                  No. .063 is correct or 1\16th amp
                  .30 is almost 5 times as resistant.
                  • allan
                    RTFM!!
                    • 5462
                    The ICP on the DR311 drum chip and the TN512 toner chip should be the right spec fuse to use.
                    Whatever
                    • copier tech
                      • 8142
                      No need to bother resetting the fuser, transfer life or image units, just turn off the warning in CE mode. (Firmware update maybe required depending on version)
                      • Synthohol
                        • 5820
                        I agree however once it's calling for a consumable it won't work. You have to turn off notifications before EOL. Then it works.
                          • May 2016
                          • 23
                          I found the fuse 1/16 on the Internet , bought and am hoping to get . Mando news of the result.
                          • Synthohol
                            • 5820
                            good luck Andre!
                              • May 2016
                              • 23
                              not sure gave the reset with fusitor 1/16 , what should I do now ??not sure gave the reset with fusitor 1/16 , what should I do now ??not sure gave the reset with fusitor 1/16 , what should I do now ??
