7135 white line
  • mrfuser
    • 1626
    7135 white line
    Replaced drum, developer units and fuser. Internal print or copy is same. Missing a line. Take a look at the pic.
  • Flash
    • 378
    Re: 7135 white line
    Did you clean the window on the write unit?
    • mrfuser
      • 1626
      Re: 7135 white line
      Yep, one of our first things.
      • Synthohol
        Certified Konica Expert
        • 5892
        Re: 7135 white line
        check the mag roller again.
        • mrfuser
          • 1626
          Re: 7135 white line
          Completely different dv unit
          • mrfuser
            • 1626
            Re: 7135 white line
            The line is same spot always whether print or copy.
