7135 vs 420 drum and developer units
  • mrfuser
    • 1617
    Anyone know if you can swap the Drum Assembly, complete, and the DV assembly from a 420 to a 7135? They look the same, but are sensors within the same?
    Thanks!
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    Re: 7135 vs 420 drum and developer units
    the 7145 is similar to the 420, not the 7135.
    you can cheat like i do and search consumables on precisionroller.
    if the part#s are the same i can cross but from what i see if the pics are accurate they are physically different.
    here is a sample Konica Minolta bizhub 420 Drums
    Konica Minolta 7135 Drums
    they take different developer too. the 7135 uses 301k and the 420 uses 511k
    • 907tec
      • 434
      Another good trick is to download the full Parts Pricing List from Konica, then look up your part number. It's a quick way to get a list of machines that use the same parts, as well as finding updated part numbers ("NLA - Use ____ instead").
      • tech28
        • Jun 2013
        • 434
        Drums on the 7135 vs 7145 are different, the ends of the drums in which the shaft goes thru are different, over the years I have used and cross used the toners/developers for those machines, from the 7020's to the 7145's, no issues. When using the 7020 dv in a 7145, the c/q is rich and very good solids for over 100k.
        • mrfuser
          • 1617
          So A 7135 and a 702 to use the same drum and developer units?
          • tech28
            • Jun 2013
            • 434
            No, those are not. Very different.
            • mrfuser
              • 1617
              Odd, 7022 parts look of identical, any idea what is different?
              • mrfuser
                • 1617
                FYI: I swapped DV unit and Drum Unit Assembly from 7022 to 7135 and it worked perfect. Only mod was swapped Toner Sensor on bottom of DV unit!
