C224e 99-03, 99-03
  • DijanJanssen
    • Jan 2016
    • 7
    [Error Code] C224e 99-03, 99-03
    C224e with 99-02 error, and C99-03 during Imaging Procces Adjustment.
    Start button flashing spontaneously blue/red while test print and gives than 99-02.
    Feed test all drawers without text is good, when text is on then gives machine during print 99-02 ?
    Sensor test are OK
    Parts that replace/switched:
    Powersupply
    Laser unit
    High voltage
    Board PWB Assembly
    Drum units
    No solution
    Anyone have any suggesties?
    • 14812
    Re: C224e 99-03, 99-03
    Have you tried updating the firmware?
    • DijanJanssen
      • Jan 2016
      • 7
      Yes firmware update gives no improvement
      • habik
        • 2013
        Pcl and ps font prints OK?
        Byting on bits.
        Firmwares HERE
        • habik
          • 2013
          What ver fw did youload and what ver is on ssw25?
          Byting on bits.
          Firmwares HERE
          • DijanJanssen
            • Jan 2016
            • 7
            Soft 25= 60
            Firmware= GD2-K9 (new 10-6-2016)
            I am now going to create a log file, see if we may see an error?
            • habik
              • 2013
              I've got 2 m\c next to each other both were on G20-K7. I am flashing one with GD2-K9 as I am typing so can compare if issue arrises.
              Byting on bits.
              Firmwares HERE
              • avecosat
                • Jun 2012
                • 305
                I`ve got 2 or 3 machine with this firmware and don`t have problem , SSD version??
                • habik
                  • 2013
                  No issue so far.
                  Byting on bits.
                  Firmwares HERE
                  • Albonline
                    • Sep 2008
                    • 1151
                    we've run into this a few times and its usually ssd or hdd
                    • paulinho
                      • Jul 2010
                      • 9
                      Just curious to know whether you resolved this issue and if so what was the final solution.
                      I have a colleague who is currently experiencing a similar code on a C454e
                      Cheers
                      Originally posted by DijanJanssen
                      Soft 25= 60
                      • TheBlueOrleans
                        • Aug 2012
                        • 232
                        Per the Service Manual:
                        1.11.5 99-03
                        (1) Contents
                        JAM type Controller JAM
                        JAM code 99-03
                        Detection timing 99-03 Image stabilization not completing a job.
                        Misfeed processing
                        location -
                        Relevant parts -
                        (2) Procedure
                        Step Action Control signal Location of electrical component
                        1 Initial check items - -
                        2 Open and close the front door of the main body
                        1.11.6 99-04
                        (1) Contents
                        JAM type Controller JAM (finisher pre-drive is not completed)
                        JAM code 99-04
                        Detection timing 99-04 The finisher pre-drive is not completed even with a print start command received.
                        Misfeed processing
                        location -
                        Relevant parts -
                        (2) Procedure
                        2 Open and close the front door of the main body, or
                        open and close the front door of the finisher.
                        You may want to check the front door sensors, if they're not registering the front door closed consistently, due to machine vibrations or unstable placement of machine (I've seen it, it does happen), it could very well be throwing a jam code as though the front door had been opened during a job.
                        I could be wrong, I'm probably wrong, I am often wrong. But check them.
                        Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
                        • jwai
                          • May 2018
                          • 509
                          I get this issue today on C450i, display 99-03.
                          I tried to disconnect PC216 cabinet and the machine operate normally......strange.
                          • jwai
                            • May 2018
                            • 509
                            The 9903 and 9913 error codes made me crazy, on C450i.
                            Every time the machine take stabilizing image after warming up, when the process finish the above codes display.
                            I check drums, developing units, sub hopper section, transfer belt, updated firmware to G00-J9 but the same issue.
                            any ideas about that?
                            • tsbservice
                              Field tech
                              • 8020
                              Can you do Initialize+Image Stabilization in service mode? Can you see patches on belt when during machine trying to stabilize you open side door?
