BizHub Pro c6500 problem pawer
  • liondor1969
    • Jun 2016
    • 72
    Hallo
    I have a konica minolta BizHub Pro c6500 that wont power up...
    i have a problem with and I have a yellow pollution in waves,if you print something white, is seen as a dirt
    I tried another drive laser, the result is the same,I cleaned cylinders, less transfer belt
    please help my :-)
  • Synthohol
    Certified Konica Expert
    • 5816
    Re: BizHub Pro c6500 problem pawer
    I think I need a translator.
    Which is it, wont power up or a copy quality issue?
    Im sorry but your post and link are contradictory and need to be explained.
    Thanks.
    • liondor1969
      • Jun 2016
      • 72
      my BizHub Pro c6500 does not start..no PAWER..not feed supply :-) is dead
      Thanks.
      • mircea
        • Feb 2014
        • 70
        Originally posted by liondor1969
        Hallo
        please help my :-)
        hello
        Try to check in the back of your printer for a white fuse on the power supply board
        all printers should have a 5-6A fuse to prevent board from burning
        take care
