bizhub c253 weird adf print "waivy" pattern on page
  • xdelios
    • Apr 2016
    • 27
    [Misc] bizhub c253 weird adf print "waivy" pattern on page
    Hello,
    I have a weird problem.
    Notice that this is only happening when making copies from the ADF.
    Everypage I copy from the ADF gets a "wavy" like ending at the right edge of the page. This "wavy" ending isn't like a smudge its just getting the original copy and give it that pattern.
    I hope my English is good enough for you guys to understand what I mean.
    I am also attaching an image with the right edge of the page to see the lines that ain't straight (original was)
    Anyone has any idea?
    Regards,
    George
  • allan
    RTFM!!
    • 5462
    Re: bizhub c253 weird adf print "waivy" pattern on page
    The ADF is not sitting properly. It is to high off the glass on one side or really skew.
    The height adjustment is made from the top of the hinge.
    Loosen the ADF slightly and adjust the skew when closed from behind.
    Whatever
      • 14679
      Check the height of the DF. With the DF closed, push down on the front left corner. If it moves you will need to adjust it down until it doesn't move.
        • 23006
        That's it right there. Thanks allan. =^..^=
