Biz hub C280 dark prints
  • coveredinoil
    • Dec 2014
    • 15
    [CQ] Biz hub C280 dark prints
    Hi
    I have a Konica Minolta Bizhub C280 which is printing darker than it
    should.
    If I take a photo it looks good on the camera, my laptop(XP) and my
    Mac (el capitan) but if I print from LT, Mac or event from a usb stick (plugged
    in printer) the Image is much darker than I would expect to see.
    Can anyone help me with this?
  • minimerlin
    • 851
    Re: Biz hub C280 dark prints
    Originally posted by coveredinoil
    Hi
    should.
    This does not give us much to work on! What is the counts on the Drums, Dev units etc? When was it last serviced? Have you called a Tech or just want us to diagnose it for free? What are the internal test prints like? Are you an end user?
    Sorry to be negative but without knowing all the facts, and seeing the output, it is impossible to say what your problem is!
    Please do not PM me without asking first.
    • allan
      RTFM!!
      • 5462
      Just before the developer runs out the prints gets to dark due to the fact that the machine will add the same amount off toner regardless of the amount of developer.
      Whatever
      • coveredinoil
        • Dec 2014
        • 15
        Sorry, let's try and answer some of the questions raised.
        Hope that answers the usage bit.
        Not sure when it was last serviced, i inherited it along with a very small business.
        I have not called a tech YET and i DON'T want it diagnosed for free, just a few pointers if there is anything simple i should check or look out for first. My business is really up against the wall (along with main others I hear you call)
        The internal test print looks ok (to me!)
        Yes I'm the end user.
        Thanks for any help
        • Synthohol
          Certified Konica Expert
          • 5868
          Try hitting utility, administrator mode, 12345678, locate expert adjustment and run gradations 3 times for each catagory.
          Gradations are the machines color calibration. If you have a users manual this is covered.
          • gerryproulx
            • Mar 2015
            • 24
            agreed do the gradations first and you can try a different driver
            • allan
              RTFM!!
              • 5462
              [ATTACH=CONFIG]33493[/ATTACH][ATTACH=CONFIG]33494[/ATTACH]
              Thanks for any help
              What is the total meter count?
              Whatever
              • coveredinoil
                • Dec 2014
                • 15
                Total = 239733
                Colour = 79280
                Black = 160453
                (Will try graduation shortly and will report back)
                • tech51
                  • 846
                  In the print driver there are settings for different applications such as cad,photo etc.
                  After setting up the gradation as previously suggested, I would play with the settings.
                  • coveredinoil
                    • Dec 2014
                    • 15
                    Wow, that's so much better. I had run gradation once before, but just the once!
                    One last question(I hope), blue looks a little washed out (not much, i can live with it if needs be) but would running through "Application - Edit Colour - Colour Adjustment" help? or is that just for the copy function?
                    Thanks again.
                    • Synthohol
                      • 5868
                      in some cases i have run the gradations 6 times each and that may help.
                      also this is a color machine yet only 1/3 of its output is color.
                      the toner and developer get stale from non use.
                      there is an electrical "condition" called Tribo, if the DV units only churn for the initialization on warm up and not regularly used it will cause the ATDC sensor to report the reading of stale toner/developer and may never adequately replenish the toner to give the best color from the machine.
                      that adjustment you mentioned is just for copies.
                      fwiw if you use the PCL driver instead of the preferred PS you can adjust each color before printing.
                      • coveredinoil
                        • Dec 2014
                        • 15
                        I'm on an iMac OS X(10.11) so stuck with PS driver (unless some can educate me a bit more!)
                        But thanks again for all the help.
