Fitting a SD-505 Saddle stitcher to the FS-519 Finisher
  • PrintHub
    • 12
    A little advice anyone
    I fitted the kit to the finisher, the problem is that the copier c203 and c253 isn't detecting the saddle stapler.
    Is there a place in the service menu where im supposed to enable it - im under the implession the machine will autodetect it?
    • 23009
    Re: Fitting a SD-505 Saddle stitcher to the FS-519 Finisher
    I believe it's called "Enabling Options", in System1 or System2.
    No, Konica Minoltas are not plug and play. =^..^=
    • PrintHub
      • 12
      There is no such option in the service menu?
      • Synthohol
        Certified Konica Expert
        • 5843
        did you connect the wire for the creasing unit? its easy to forget, its such a crazy install
        • PrintHub
          • 12
          Yea sir i did. Even made sure every time i powered it up
          • habik
            • 2013
            Have you repositioned one of the trays?
            Think thats required for the booklet saddle to come to the finisher exit level. Think even sensor is to be moved.
            Byting on bits.
            Firmwares HERE
            • habik
              • 2013
              Ahh firmware , just re-flash it for the sake of it.
              Byting on bits.
              Firmwares HERE
              • PrintHub
                • 12
                Byting on bits.
                You are correct sir...you have to reposition one of the trays...the top one to be more specific.
                I did do this. When you do power the unit the booklet saddly will come down to the finisher exit level and go back up.
                The problem is that I don't see any movement from the saddle stitcher itself. Almost as it it is dead.
                Also I don't see any options under finisher for saddle stitching
                any other ideas?
                • PrintHub
                  • 12
                  Thank you gents for your help. It was much appreciated.
                  After I installed a punch kit into the finishing unit the saddle stitcher started working perfectly.
                  Slightly adjusted the centre staple position in the service menu and everything is now just perfect.
                  Once again, thank you!
