BHC360 puts cyan background on prints but not copies or internal prints???
  • Desert Rat
    • May 2008
    • 1089
    I'm sure I'll have to go back and check the symptom again, but I did see it leave a cyan background
    on prints, even in the erased area on the edges. The copies look good black and white and color.
    The half tones look smooth and even. The test prints also look ok.
    Is there a setting for some kind of bias voltage for printing but not coping?
    DR
  • habik
    • 2013
    Re: BHC360 puts cyan background on prints but not copies or internal prints???
    Dev Bias choice ON/OFF
    Re-seating C-IU. Cleaned contacts, chargers.
    I presume you tried Stabiliser Background reset and then after Gradations adjust?
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • Desert Rat
      • May 2008
      • 1089
      habik,
      Thank you for the reply. I did run the gradation but not the stabilizer reset. I should've looked a little more.
      I will see what it has to say about the dev bias shoice.
      Thanks again
      DR
        • 23009
        If the stabilization and gradation doesn't help, I wouldn't be a bit surprised of the cyan is overtoned. Take a peek in the waste bottle. Is 2/3 of the total volume blue? =^..^=
