EFI ES-1000 Spectrophotometer
  • liondor1969
    • Jun 2016
    • 72
    Hallo
    I buy a EFI ES-1000 Spectrophotometer to calibrate my KM C6500,I have a problem,WS not found my ES 1000,in windows 10 appears installed. I have old licensee 1.3 Fiery Color Profiler Suite but this not work wit win 10.WiFiery Color Profiler Suite si compatible with my ES 1000 + win 10 ?
    Plese help
    TX
  • ss12
    • Jul 2008
    • 289
    Re: EFI ES-1000 Spectrophotometer
    Have you tried using CWS to calibrate it?
    • peter42
      • Jan 2012
      • 110
      You have to install CWS from master installer from DVD. Then you get the ES1000 driver in your system. Dont go to subdirectory and install CWS from there. That fails in most installations.
      • Synthohol
        Certified Konica Expert
        • 5849
        maybe some answers here.
        • liondor1969
          • Jun 2016
          • 72
          I have instal CWS on my pc,on pc i have WIN 10 this is compatible with new CWS 5.8..on this my ES 1000 not detect.I have old CWS on my Fiery control,I calibrated from there,but I want to do a color profile for Photoshop,i work only in Photoshop.When i print from Photoshop,colors is not ok,i must tray export PDF with color profile CMYK FOGRA39 i hop this is ok or better i must create my picture profile,please help my with same recommendation :-)
          TX
          • Mick01
            • Nov 2012
            • 362
            Hi,
            If you read the PDF that Synthahol attached you will find that the license for the software is linked to a specific spectro device. Your software would most likely have been licensed using another device and will not work with the ES1000 you have just purchased.
            I am a bit confused as to why you need a specific profile to use to get accurate color out of Photoshop? Have you tried exporting one of the "standard" output profiles that come with the EFI controller? Are you trying to embedd this profile in your files you prepare in Photoshop or using it as a "working space" for soft proofing?
            • liondor1969
              • Jun 2016
              • 72
              Originally posted by Mick01
              Hi,
              Hi
              i ned this spectometer to calibrate my C6500, i tray al profil from C6500,but the perfect color ghet with profile calibrate on paper type use.I calibrate c6500 direct from fairy,naw is ok.Is ok to export from photoshop RGB to fairy,than fairy to convert this on CMYK ?
              tx
              • liondor1969
                • Jun 2016
                • 72
                Hallo..please
                I need
                Fiery Color Profiler Suite 4.6 - 4.7 :-) to work with EFI ES1000 + win 10
                TX
                • Synthohol
                  • 5849
                  Activate a Color Profiler Suite license
                  The downloaded Color Profiler Suite license file must be on the computer’s desktop for activation. To activate the
                  license on that computer, you must connect the correct spectrophotometer. If no spectrophotometer is connected,
                  the Demo mode message appears.
                  If your computer has no Internet access, you must copy the license file to the desktop of the computer that has Color
                  Profiler Suite installed.
                  1 Connect the licensed spectrophotometer to the computer.
                  2 Do one of the following:
                  In the Color Profiler Suite main window, click Help > Activate License.
                  Click Activate License in the Dongle Not Licensed window.
                  • liondor1969
                    • Jun 2016
                    • 72
                    I have efi color profiler suite 1.5.9 with efi ES-1000 on win 10 64bit,i want to create a color profile for tip of paper i use.I have a error wen i start the program.. please conect efi spectometer ES-1000 OR DEMO..
                    Plese help my wit recomandation..thanks
                    • methogod
                      • Dec 2008
                      • 921
                      To calibrate the printer you need Command Workstation to calibrate your monitor you need the Color profiler suite.
                      Cheaper to buy a good Dell monitor, never need to calibrate anymore.
                      • liondor1969
                        • Jun 2016
                        • 72
                        With Command Woerkstation is possible to liniarisation may C6500,i tray to create paper profile
                        • cmykburnley
                          • Oct 2018
                          • 5
                          Hi Guys
                          Wondering if you can help
                          Ive bought a 2nd hand ES-1000 with the profiler suite.
                          Im running windows 10 and command workstation.
                          I can get the es-1000 to communicate with cw no problem.
                          However the software itself i cannot. Keeps asking me to connect the spectrometer. So will only work in demo mode.
                          I would like to create a custom output media profile for cw
                          Thanks in advance
                          • davel
                            • Oct 2011
                            • 1107
                            Get spectrometer and license from the seller otherwise bad luck.
                            • cmykburnley
                              • Oct 2018
                              • 5
                              Ive got the spectrometer and it came with the profiler disc.
                              I have the licence code on the instructions inside in the box
                              just doesnt let me input it anywhere
