EFI ES-1000 Spectrophotometer
  • Synthohol
    Certified Konica Expert
    • 5849
    #16
    Re: EFI ES-1000 Spectrophotometer
    What model cipier\IC-xxx?
    Maybe you need the latest CWS downloaded from efi.com?
    • cmykburnley
      • Oct 2018
      • 5
      #17
      Its the latest version of cws.
      CWS picks up the spectrometer no problem
      Im presuming its the software colorprofiler wont work as its xp and not windows 10
      • jotunn
        • 618
        #18
        You need to generate license file for Color Profiler Suite here:
        EFI License Fulfillment
        You can use License Activation Code (LAC), or just your ES-1000 serial number. When your spectro is not licenced at all, you will get an error message.
        Sometimes you can get 2nd hand spectro without any documents, then above website can help you check, if it's connected to CPS licence or not.
        When your ES-1000 has got licence for CPS, the site will show you a _maximum_ version of Color Profiler Suite for your spectro - newer versions will not work!
        Download and save your licence to your computer's desktop. The license file must be on the desktop for activation to occur.
        Then, i
        n the Color Profiler Suite main window, click Help > Activate License.
        • cmykburnley
          • Oct 2018
          • 5
          #19
          Then, i
          Hi mate
          thanks for your reply
          Ive clicked the link, entered the serial number and this is the error code i receive
          The EFI Spectrophotometer you entered does not correlate to a licensed CPS. Please re-enter your EFI Spectrophotometer serial number or enter the License Activation Code (LAC) that came with your software.
          • jotunn
            • 618
            #20
            As I remember, there should be also a sheet of paper with Licence Code (LAC) somewhere between the other documents in your package.
            With licensed ES-1000 you should have in your bundle:
            * Eye-One Pro Spectrophotometer and Calibration Plate with matching SN.
            * USB cable
            * Positioning Target
            * Flat Panel holder
            * Scanning White board
            * Documentation
            * License (LAC) - and probably serial number (I don't remember)
            * Certification of Performance
            * Software CD with drivers and Color Profiler Suite (version maching your license)
            * Carrying Bag
            However there were ES-1000 (as well as ES-2000) versions without licence for Color Profiler Suite.
            Sample contents of licence file (rich version) for CPS v3.0:
            INCREMENT AdvancedEditor CLRPRFLR 3.0 permanent uncounted \
            HOSTID=SPECTROMETER=709679 ISSUED=27-Oct-2015 NOTICE="***** \
            EAC=A-15300-52166644 *****" TS_OK SIGN="0075 3600 B659 E980 \
            1AEF C587 DDA4 3300 3D47 BFA6 2BDC F6C6 0F90 1750 D4D9"
            INCREMENT DeviceLink CLRPRFLR 3.0 permanent uncounted \
            EAC=A-15300-52166644 *****" TS_OK SIGN="00A8 049F 0F9E D878 \
            816D 99F9 2848 9B00 02C6 6296 E45E AE20 000C B6BC 242C"
            INCREMENT PrinterProfiler CLRPRFLR 3.0 permanent uncounted \
            EAC=A-15300-52166644 *****" TS_OK SIGN="006E B856 3F8C AE44 \
            B672 A8B0 7FAF AA00 9A8C 10E2 71FF 5CF1 E317 1B48 A68B"
            INCREMENT MonitorProfiler CLRPRFLR 3.8 permanent uncounted \
            EAC=A-15300-52166644 *****" TS_OK SIGN="0056 EE53 CFB5 E332 \
            5C00 5805 179D A600 C0D9 AFB4 92A0 6CFF DE24 D776 25CE"
            INCREMENT 3DGamutViewer CLRPRFLR 3.0 permanent uncounted \
            EAC=A-15300-52166644 *****" TS_OK SIGN="0014 F941 EF83 22C0 \
            1FE8 F5C2 52FA 2800 E6F5 58B3 F3AD 214C 5D68 7E6C 79C7"
            INCREMENT ColorVerifier CLRPRFLR 3.0 permanent uncounted \
            EAC=A-15300-52166644 *****" TS_OK SIGN="00F0 BF61 3E1B 74BC \
            59CD 2206 F05E 2D00 EE36 CDAC 1462 EDDA D4B5 A6A6 B3DD"
            Basically ES-1000 without license is almost worthless nowdays. You can do only linearization with Command Workstation.
            Or you can try to use free software like Argyll or Coloris.
            • methogod
              • Dec 2008
              • 921
              #21
              lets start with this...
              what are you trying to do? How do you need to use it?
              making profiles?
              Calibrating monitors?
              CWS and Onyx all recognize it internally.
              • cmykburnley
                • Oct 2018
                • 5
                #22
                making profiles?
                Id like to make profiles with it, hence the issues
                • tulintron
                  • Jul 2014
                  • 668
                  #23
                  Originally posted by liondor1969
                  I have instal CWS on my pc,on pc i have WIN 10 this is compatible with new CWS 5.8..on this my ES 1000 not detect.I have old CWS on my Fiery control,I calibrated from there,but I want to do a color profile for Photoshop,i work only in Photoshop.When i print from Photoshop,colors is not ok,i must tray export PDF with color profile CMYK FOGRA39 i hop this is ok or better i must create my picture profile,please help my with same recommendation :-)
                  TX
                  To create a profile through the ES-1000, you will need a license and software.
                  By the CWS, just calibration, or buy CWS license
