IC 408 Network issue
  • selmila
    • Aug 2012
    • 133
    hi all,
    IC 408 dose not connect to the pc,i have re installed the fiery software and also cleared the cmos but still fails to respond or connect. any help or suggestion will be appreciated.
  • sadanand
    • 62
    Re: IC 408 Network issue
    1) try for pinging
    2) if not possible go through scan if you locate IP address
    try pinging again
    • Synaux
      • Mar 2012
      • 1224
      Try manually setting the IP address if you have not already...
      When you connect the Ethernet cord are the leds on the port lighting up?
      • mrwho
        Major Asshole!
        • 4299
        Are you using the correct network connector? I once reinstalled the system software on one just to find out that the customer had changed the cable from one port to the other...
        Mascan42
        Ibid
        • Synaux
          • Mar 2012
          • 1224
          haha! I bet that made you happy.
          • mrwho
            Major Asshole!
            • 4299
            You think?
            Mascan42
            Ibid
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5892
              one of the buttons on the panel will show the IP address.
              there are 2 lan ports on the fiery, use the bottom one.
              the scsi cable from fiery to the video interface, reseat it.
              just some basic suggestions.
              oh, what model copier? on the newer ones there are bit switches to change.
