C554e and C554 operating panel
  • habik
    • 2013
    Has anyone succesfully swapped operating panels between these two devices?
    Are they compatible? Schematics shows yes.
    Firmwares HERE
  • mo0651
    • 1054
    Re: C554e and C554 operating panel
    One slides open and one does not. So never tried.
    • allan
      RTFM!!
      • 5462
      Not sure if the firmware would support the on screen keypad if you are downgrading.
      Don't think there should be much trouble if you are using the non e series screen on an e series machine.
      That is if the connectors are the same.
      Whatever
        • 23010
        I was just going to mention the firmware. I just this week installed an 'e' series panel, and found it inoperative until I re-loaded the firmware. Apparently the new panel was at an incompatible firmware level. If one were to read the destructions that come with the new panel, one would also come to that conclusion.
        Will a C554 work on a C554e? No idea. Try it. Then immediately do the firmware. If it fails I think that will answer your question. =^..^=
        • Woxner
          • Jul 2011
          • 854
          there is no firmware on the panels when new thats why you have to load it when a new one is installed and tell it english and i think machine type
