C253 to C224, Import / Export ???
  • copyman
    Owner / Technician
    • Sep 2005
    • 4750
    Can the address book, etc be Exported from a C253 and Imported to C224 ? Not sure if the newer machines use.txt file like the older models do?
  • Synthohol
    Certified Konica Expert
    • 5878
    Re: C253 to C224, Import / Export ???
    you can download the address book via PSWC and apply it to the 4 series.
    • wseyller
      • Sep 2012
      • 1129
      You should be able to from pagescope data administrator.
      Sent from my Nexus 6P using Tapatalk
      • copyman
        Owner / Technician
        • Sep 2005
        • 4750
        Update
        I tried exporting address book from a C253 and importing to C224 and it didn't work. I even tried changing from a .txt file to a .dat file which the "4" series uses and it still didn't work.
        Called my friend from K/M and he told me they had a lot of issues importing/exporting from the 2 & 3 series to the 4 series. Basically everything has to be put back in manually
        • allan
          RTFM!!
          • 5462
          As per wseyller use data administrator make life with KM machines a whole lot simpler.
          Whatever
          • MFPTech
            • 486
            The way i do it is
            1. add 2 new destinations on the new machine and export the address book
            2. export the address book of the old machine
            3. Copy / paste and import
            Sent from my SGH-I337M using Tapatalk
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              I have done it from a c253 to a c554e but you do need the latest version to accomplish this.
              Hook up the old with crossover and load into data admin (both if you have a switch makes it easier)
              download the address book and save it.
              hook the other up import the address book and push it out to new machine.
              If you have both hooked up then load both machines into data admin
              goto multiple machine mode and copy the address from one to the other without needing to save.
              • wseyller
                • Sep 2012
                • 1129
                I do this with new installs all the time. I hook up with Ethernet cable direct to old copier. Register in data admin software. Load address book. Export address book to tab text type file.
                Then hook up laptop to new copier. Load address book then import the file. Then you map each column to the appropriate field. Then export back into the new copier. After you do it a few times it is second nature. You can do the same with account track id's.
                • allan
                  RTFM!!
                  • 5462
                  Have a job coming up with RFID card.
                  I wonder if the card registration info will export with the authentication data?
                  I know it does with the same models not sure between models.
                  Whatever
                  • MFPTech
                    • 486
                    Originally posted by MFPTech
                    The way i do it is
                    i would like to add that i don't need my laptop at all to do this, nor the notorious Konica Admin software.
                    I export the address book of the old machine on customer's PC.
                    Connect the new machine and add 2 addresses. Export the address book of the new machine on the same customer's PC.
                    Open both old and new files on excel and copy paste the data from the old to the new one.
                    Import the new file to the machine - Done!
                    This is such a piece of cake that sometimes i call secretaries and tell her how it's done. it takes them no more than 5 minutes!
                    • avecosat
                      • Jun 2012
                      • 305
                      Make sure you have update last firmware the two machines and test different version of pagescope data administrator .......
