BizHub 222 Drum scored at rear- scrapes mylar off developer unit.
  • rbazan
    • Dec 2013
    • 70
    [Misc] BizHub 222 Drum scored at rear- scrapes mylar off developer unit.
    I replaced the Drum and Developer unit (Precision) and machine ran about 30,000 and the Drum is scored at rear. The developer Unit rear mylar is damaged. I replaced this Drum and Developer because of the same problem before. I removed 1 shim from rear of new Transfer Roller assembly to put less pressure. I'm worried the problem is not solved. What should I check?
    Thanks.
  • habik
    • 2013
    Re: BizHub 222 Drum scored at rear- scrapes mylar off developer unit.
    Re-connect and clean all HV contacts.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
      • 14812
      Replace the dev spacer rollers and replace the BH222 transfer roller with a BH432 transfer roller. You will also have to replace the drum and dev again. Use OEM toner!!!! It will save you a lot of headaches.
      • rbazan
        • Dec 2013
        • 70
        Is there a new part number for those dev spacers or do I use the one in parts manual (that I haven't looked for yet.)
        [RANDOM THOUGHT! When I installed the developer I didn't put the mylar shields that come with new drum on developer unit to prevent it getting under the developer units 'developer roller mylar insulators'-that might cause the drum to rub on the mylars---.......]
        • Woxner
          • Jul 2011
          • 851
          you dont need those mylars. i have never used them
          • REGSIS
            • May 2016
            • 435
            Me neither, just be cautious when you put new developer in dev unit.
            BTW I have those symptoms on dev unit, but after 300K which is normal. Life expectancy of dev unit is 320K on bh 222.
            • CraigW
              • Dec 2010
              • 417
              KMBS A1UDR90100 Ds Roll Kit
              2 new style collars, and other items included.
              What is the count/% life remaining on that developing unit ??
              • habik
                • 2013
                Maybe Hansoon may need a plug in.
                He is manufacturing some collars,
                http://www.copytechnet.com/forums/ko...uestion-3.html
                hence see his avatar picture.
                Firmwares HERE
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4721
                  I agree you need the dev collar. I only replace the rear one. You can also buy just the small mylar if it is torn. I think the collar is overpriced at $15 USD. I'm going to check out a collar I saw from canon. Not sure what model but when I see them again I'm going to get them. I think they are the same size and only $5.
