C450 prints blue and "ghost images"
  • AVW
    • Apr 2016
    • 57
  • copier tech
    • 8070
    Re: C450 prints blue and "ghost images"
    Clean all the contacts in the rear of the machine & on the cyan image unit.
    I would also update the firmware to the current version.
    • AVW
      • Apr 2016
      • 57
      • Woxner
        • Jul 2011
        • 822
        does not matter if the image unit has only 3 k i have seen these go bad several days out of the box. did you replace the unit or just the drums . did you run gradation and inialize and reset
        • AVW
          • Apr 2016
          • 57
          • Woxner
            • Jul 2011
            • 822
            run the other mode i mentioned it reset everything back to 0
            • copier tech
              • 8070
              By cleaning I mean the contacts in the back of the machine, toner can leak down & cause poor contacts
