c-2206 on Pro 951
  • Issac-brock
    • Jan 2015
    • 61
    Re: c-2206 on Pro 951
    Originally posted by allan
    Its a crappy design...
    If it codes out its was using blade 1 and tries to switch to blade 2. That is around 375K after replacing the blades?
    Now i don't even strip and clean the unit i just flip it to blade 2 manually.
    Then around 750K i will change blade 1 into position 2(remove both and change around) and leave it there until the drum fails.
    The cable inside the unit climbs off its guide while its not under tension and tilted to one side. So caused by installing the blades to start with. Keep it level.
    I get paranoid if the machines run to long with no calls so getting that code forces me to check it.
    Strip and reinstall the the cable then test it a couple of times by triggering it by hand.
    Mine is doing it with a new blade unit installed. Replaced unit due to codes, still codes, reboot and it prints again. I see nothing physically wrong however have just ordered the new style blade unit for next call.
    • Issac-brock
      • Jan 2015
      • 61
      Originally posted by antone
      Did you inside machine...the wall of fame ...I had same problem and found paper inside unit! I did Printer Control, firmware, complete cleaning unit! Not hard to do ...long screwdriver helps
      Sent from my SM-N950U using Tapatalk
      Do you mean the waste toner port that mates with the cleaning unit when the process unit is engaged? I see a screw above in plastic, one below on a metal plate and an E-ring on the shaft?
      • allan
        RTFM!!
        • 5462
        Could be a bad contact on the connector or dirty connection block.
        Guessed you did make sure its on the right blade and the counter cleared.
        Whatever
        • Issac-brock
          • Jan 2015
          • 61
          #19
          Yes, triple checked the blade position. cleaned the connectors, added 2 screws to hold process unit snug. Will wait and see.
          • antone
            • Oct 2014
            • 344
            #20
            Yes,i found a little piece of paper in there .....drove me nuts!
              • 23008
              #21
              We had a 1250P and a 1052 recently that motor M22 shorted, and blew the ICP on the PRCB. =^..^=
