c-2206 on Pro 951
Re: c-2206 on Pro 951
Do you mean the waste toner port that mates with the cleaning unit when the process unit is engaged? I see a screw above in plastic, one below on a metal plate and an E-ring on the shaft?Comment
Yes, triple checked the blade position. cleaned the connectors, added 2 screws to hold process unit snug. Will wait and see.Comment
We had a 1250P and a 1052 recently that motor M22 shorted, and blew the ICP on the PRCB. =^..^=If you'd like a serious answer to your request:
