C550 Fiery doesnt refresh without disconnecting
  • methogod
    • Dec 2008
    • 921
    C550 Fiery doesn't refresh without disconnecting....
    Tried wiping fiery from inside command workstation - no change.
    Never had to reload software but its an old machine, any suggestions?
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: C550 Fiery doesnt refresh without disconnecting
    Web into the fiery launch configuration. You need java and try to put it back to factory. Did you try clear server from the copier panel? The jobs will be wiped but settings remain. Best to just Web into it with Firefox or whatever browser that will open the fiery Web page.
    Good luck!
    • methogod
      • Dec 2008
      • 921
      logged in with correct admin /pass and it seems to be fine now... thanks,
