reset tool, A145FW.tar
  • copyman
    Owner / Technician
    • Sep 2005
    • 4717
    Does anyone have the firmware reset tool for Biz 224. It is A145FW.tar.
    Or can you tell me where it is on the K/M SSD website? I did a search but nothing came up. Looked through the C224 reg & special F/W's and not there.
  • mx6turbo89
    • Oct 2013
    • 154
    Re: reset tool, A145FW.tar
    Here it is: https://www.dropbox.com/s/jh313uwow7...145FW.TAR?dl=0
    • copyman
      Owner / Technician
      • Sep 2005
      • 4717
      Thanks mx6 but for some reason I got a message it could not open. Can you try sending again or a different way.
      Thanks again
      • mx6turbo89
        • Oct 2013
        • 154
        Thanks again
        Sorry, try this link: https://www.dropbox.com/s/qk80vwdscv...145FW.TAR?dl=0
        • copyman
          Owner / Technician
          • Sep 2005
          • 4717
          Same thing happen. Maybe I'm doing something wrong? I click download and it downloads a 10KB tar file. Then what am I supposed to do with it. I usually have to unzip firmware or something?
          • mx6turbo89
            • Oct 2013
            • 154
            'TAR' is the correct file format. Here's the instructions:
            Copy the .tar file to the root folder of USB flash memory stick.
            Install the USB flash memory into USB maintenance slot to download firmware.
            Turn the main SW ON.
            "Data initialization completed!" is shown.
            Turn the main power switch OFF.
            Remove the USB flash memory from the MFP maintenance USB port.
            Turn the main SW ON. CD390 error is indicated on the operation panel (normal operation).
            Let the MFP reboot two times (on its own) until you see the Restore Tab on the control panel.
            Turn the main SW OFF.
            Upload the latest firmware.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4717
              Cool. Thanks
              • dannu
                • Jun 2016
                • 25
                SSD motherboard can reset it?
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4717
                  Firmware or reset tool didn't work. Still same problem. Tried swapping from another C224, hdd , ssd board, memory dimms, still same issue. I suspect a problem with MFP board.
                  This is exactly what is happening:
                  Power machine on and you hear machine cycle normally, display shows the pillars (or whatever they are), then a dot appears at upper right corner of display like when you have a flash drive in serv slot to update firmware, few mins later this message comes up on display:
                  Firmware update
                  Error
                  This is invalid memory.
                  Please make sure the external memory.
                  I know the flash drive & firmware is good because I have used it in other c224's plus if I try and update this machine it gives me checksums on scanner, printer,ADF but shows NG for MFP.
                  Any help appreciated.
                  • habik
                    • 2013
                    Firmware update
                    Error
                    Just to clarfiy, is it C224 or Bizhub 224?
                    Is the machine connected to network during update? If it is make sure you disconnect it prior to uploading firmware.
                    opt 2
                    Try to re-format the stick again and copy only one firmware to the root of the USB.
                    When uploading, check the machine and type settings!! Then set accordingly and hit FIX
                    Then try and upload only MFP (this at least make it faster) When it updates MFP reboot and doo the rest ADF, Scanne, Finisher etc
                    hope this helps.
                    Firmwares HERE
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4717
                      Sorry just realized I wrote 224 on original post. It is a "C"224. Thanks for the suggestions. I will try them and report back.
                      • Woxner
                        • Jul 2011
                        • 850
                        A145FW bizhubC754/C754e/C654/C654e/C554/C554e/C454/C454e/C364/C364e/C284/C284e/C224/C224e
                        A55VFW bizhub 554e/454e/364e/284e/224e
                        A61FFW bizhub 754/754e/654/654e
                        These are the correct tar files for each machine
                        If you load the wrong one it will give that message.
                        • yasinzaeem
                          • Jan 2017
                          • 8
                          A145FW how i download this file. pls give me suggestion
                          waiting for reply
                          thx
                          • ttdsp
                            • Jul 2015
                            • 5
                            waiting for reply
                            thx
                            can someone plz provide A61FFW
                            • gtr5320
                              • Dec 2016
                              • 32
                              Can someone provide A55VFW?
