AirPrint mystery on a new C658
  • RevilZ
    • Sep 2016
    • 3
    [Misc] AirPrint mystery on a new C658
    I have run into a mystery with the new C658 model machine, AirPrint is missing. The setting option for it just doesn't exist. The button is gone but the space where it should be(in the menu) is still there, like it has been disabled somehow. I have turned on Bonjour and made sure there wasn't any weird network things disabled then did a network setting clear from service mode.
    Still no Option. According to KM this machine has the ability and should do it natively. There are only the initial release firmware out currently and the only special firmware that seems to do much doesn't mention AirPrint anything. though some of the things are face palm inducing as usual.
    Any thoughts or ideas as to where the setting might have gone or if there is another parent setting that's new to these machines?
    Thank you!
  • habik
    • 2013
    Re: AirPrint mystery on a new C658
    Check SSW168 in System2
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • Synthohol
      Certified Konica Expert
      • 5846
      Check out admin mode network settings page 2 for airprint.
      • emujo
        • Jun 2009
        • 3009
        It's the function version..softswitch 25 to a hex 40 (I believe). Emujo
        • Woxner
          • Jul 2011
          • 850
          you might also have to update the voice firmware to update the function. the soft sw may not work without the update
          • wseyller
            • Sep 2012
            • 1129
            It is the function version like emujo said. Already had one of our techs go thru that on this model.
            Sent from my Nexus 6P using Tapatalk
            • RevilZ
              • Sep 2016
              • 3
              I will check the soft switches and version stuff. Thank you for the help. will reply with resolution.
              • HoonBoy
                • May 2011
                • 130
                on C458-C558-C658 series AirPrint needs to be activated with a license... Got one general for all machines...
                • FixStuff
                  • Aug 2015
                  • 16
                  Airprint does not need a license. It's the function version like Emujo said.
                  • RevilZ
                    • Sep 2016
                    • 3
                    OP here - So When I updated to the G3 firmware and set Sw. 25 to 60 Airprint settings showed back up. I had another machine in the office with the same out of box experience, and the same thing fixed it.
                    Thank you all for your assistance.
